Recommendations and suppliers of a 2-way system
Recommendations and suppliers of a 2-way system Please consider donating to help us continue to serve you.
Old 10th November 2014, 10:59 PM   #1
ActualRoyo is offline ActualRoyo  Australia
Default Recommendations and suppliers of a 2-way system
Hi guys,
first of all, I'm new here but if felt like this was the right forum to post things like this.
I'm a designer and lately I've been interested in audio. I have basic knowledge of building and the different elements to of the speaker Etc so I don't have to be too basic.
Anyways, I'm looking at constructing a 2-way system that I would design myself of course and the reason is that I find speakers often clunky or bulky. They often stand out a lot in a negative way. Personally I find that speakers has developed to a point where you can have a small speaker with a great sound for your normal home and I guess this is where I'm focusing my design.
So my question is; what do you recommend, what building stones would I need? I'm up for any thoughts about this subjects, whether it's active or passive, capacitors, terminals anything.
Also, where would U get the drivers...?
Have been looking around this morning on this forum but haven't found anything.
It's a project that is slightly price orientated so maybe suppliers from China?
Post your thoughts, comments Etc. Much appreciated!
PS. Live in Melbourne but most things are quite expensive here though...
I have a manufacturing thought behind it all depending on outcome.
Old 10th November 2014, 11:24 PM   #2
gvasale is offline gvasale  United States
To me, bigger is always better. I can' say it any other way
Old 10th November 2014, 11:29 PM   #3
Yeah, I understand the concept of size when it comes to speakers. A large speaker deliveres more, simply put but the need of a more compact speaker is greater and will appeal to a larger crowd etc. A lot of people live in apartments, or having a nice office where they want some speakers to fit in because they appreciate the looks and the sound of a bit more worked speakers. Size have to be compromised in those cases.
I'm focusing on maximum 8" but pref around 5.25"
Old 11th November 2014, 02:44 AM   #4
The speakers should always be bigger than the desk...
Seriously, once a co worker stop by the house on the way back from fishing and his eyes popped when he saw the speakers. They are large. Good luck with your quest
Old 11th November 2014, 03:10 AM   #5
PeteMcK is offline PeteMcK
Most guys here like big ugly macho designs, black cone speakers; For max SAF I'd go the opposite - slim, curvy design, light colours, white cone speakers... unfortunately white cone drivers are relatively rare, the most affordable are probably Fostex drivers, which would indicate a Full range + helper woofer design for best sound/$
(I have a design in mind which I may get around to once I've got my man-cave system finished ;-)
"A Fenderr Telecasterr has mair penetration than an AK47" - Alex Harvey
Old 11th November 2014, 07:49 AM   #6
Thx for the honesty
Yeah, often it's either one. You are a design follows function or the other way around but that's ok... I'm pretty much in the middle. I just want sound to look better than it does.
I'll have a look at Fostex drivers. I think full range + sub would be ok. It would create a different design but that's ok.
When you buy drivers like that, do you head to the mothership straight away or is there different retailers etc?
Old 11th November 2014, 11:43 AM   #7
KaffiMann is offline KaffiMann  Norway
Fanatic
KaffiMann's Avatar
What about this?
SEAS KingRO4Y
You could probably chop the design up in 2 pieces/channel if you want to.
I've seen them in real life, they are not huge, but not tiny either, very pretty for a traditional boxed design.
Edit:
There are plenty of coax/small fullrange drivers that can be built into small boxes or run OB. You can also make several miniature subs with drivers like Tang Band W6-1139SIF or equivalent, and just shove them into whatever small space you have, they can fit into many places if you're just creative.
Old 13th November 2014, 11:47 PM   #8
Thank you for the suggestion! The data is quite good I must say but I couldn't find a price. They look like they're expensive
I'm not too focused here if the driver itself looks good or not, because it would probably be hidden anyways behind a mesh/net as they quite commonly are.
Originally Posted by KaffiMann View Post
What about this?
SEAS KingRO4Y
Edit:
Old 14th November 2014, 01:34 AM   #9
No Seas distributor in Aus any more, you'd have to import them; equivalent quality available locally are SB drivers, distributor Wagner: Speaker Drivers, Audio Speakers & Pa | Wagner Electronics, wagneronline.com.au
Re:"do you head to the mothership straight away or is there different retailers etc" - for prototypes, get your drivers from the local distributor, it's a different game if you're buying commercial qtys though...
Old 14th November 2014, 04:08 AM   #10
I'm originally Swedish and Seas looks like it's an .no company so that I could sort out... no drama
Wagner's seems like the site I'm after at the moment, just to browse a bit, getting back into the Audio parts (was a while ago I dealt with all the stuff if I didn't mention that in the first post). Thank you!
What do you mean "it's a different game"?
Recommendations and suppliers of a 2-way systemHide this!Advertise here!
Cheap 8" midbass driver for small sealed system - recommendations please! bluetomgold Multi-Way 12 23rd May 2018 08:49 AM
Suppliers jimbones Multi-Way 0 15th June 2012 03:48 PM
Adire suppliers Wingfeather Multi-Way 6 13th September 2003 03:55 PM
torroidal x-former suppliers? mnewport Tubes / Valves 7 6th June 2002 03:50 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
