How to use regular speakers in place of 4-wire in house speakers?
How to use regular speakers in place of 4-wire in house speakers? Please consider donating to help us continue to serve you.
Old 10th November 2014, 03:00 PM   #11
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
Originally Posted by semmyroundel View Post
Picowall, do you use a translating pogramme?
It happens sometimes. I get remarks by forumers also in my OT ( orig. tongue )
If so take a deep breath and delete it because I don't understand a word you say.
Mmmhh...I was thinking of making them open, by destroying the rear baffle, actually.
Old 10th November 2014, 11:11 PM   #12
R.I.P.
No, I'm not interested in that, I just wanted to know if I could
use my QAcoustics concept 20 units on this music system.
Hi, and the short answer to that is no, rgds, sreten.
FWIW such systems usually have a very cheap 2 or 3 way built
into the front driven by one amplifier, and a hidded rear driver
in a 4th order bandpass with a large front port driven by the
other amplifier. As well as an active x/o they may or may not
have EQ built into the amplifiers, its anyones guess. Without
measuring and modifying, a very difficult set up to improve.
Old 11th November 2014, 01:25 AM   #13
semmyroundel is offline semmyroundel  United Kingdom
Thanks sreten, that's what I needed to know.
I know it's just a micro system, but having a mini disc collection, I was just concerned that if the speakers went, I'd lose the functionality of the whole unit.
Guess I'd better get onto Ebay and see if anyone is selling a set secondhand (a preoccupation of anyone with obsolete equipment).
Old 11th November 2014, 11:55 AM   #14
system7 is offline system7  United Kingdom
system7's Avatar
You guys have lost me completely here.
This isn't very hard, is it?
Those Q Acoustics Concept 20 are biwireable 4-6 ohm speakers, whatever that is worth.
But you can bridge the woofer and tweeter inputs and run them off a single cable. The bridge is shown below. Seemples. Then behaves just like any other speaker.
"Per ardua, ad astra." Best Regards from Steve in Portsmouth, UK.
Old 11th November 2014, 09:38 PM   #15
Hi Steve, you are right, and nice choice, I too have the white ones.
But we're talking about the Pansonic speakers, not bi-wireable but bi-wired, as in they have two wires coming out of the back of the speaker.
One goes to + and - on the high frequency output of the amp and the other to the low frequency output of the amp, in other words there are 8 speaker terminals on the amp, presumably the crossover is inside there too.
Old 11th November 2014, 10:19 PM   #16
system7's Avatar
Well, you can connect your Q Acoustics speakers to either output. Nothing will break.
Presumably one output will sound bassy, and the other output will be top end only if it's wired and filtered as you guess?
Sounds interesting actually. Poor man's active filter. What is the model number? I expect google can turn something up.
BTW, these sort of old stack units often have provision for an equaliser. It possibly won't work at all unless you bypass the equaliser input and output section with some phono leads.
Old 11th November 2014, 11:10 PM   #17
Interesting, you are one step ahead of me Steve.
The unit's in my daughter's bedroom so I can't look until tomorrow.
I'll post model number, you may find out something.
Regards, Julian
Old 12th November 2014, 12:27 AM   #18
R.I.P.
Steve is one step well behind any commonsense.
I've already described the commonsense.
In all reality you need to convert your minidisc
collection to VBR MP3 or WMA via a decent PC
card, or buy a standalone minidisc player/
recorder, they are now dirt cheap.
So go for the most expensive and rare,
not much more than the cheapest.
However that wil only delay conversion
for one generation, but at least your
source for conversion will be much
better than a mini system, unless
the mini system is the recorder.
rgds, sreten.
How to use regular speakers in place of 4-wire in house speakers?Hide this!Advertise here!
Regular speakers with 70V amplifier? djduck PA Systems 9 29th September 2014 04:48 AM
Can I use regular stereo speakers for car audio? Racket Scientist Car Audio 10 30th May 2010 05:07 AM
Building Speakers Using Regular Plywood kvk Full Range 15 25th February 2008 11:58 PM
Thru-House Speakers funkyluggs Multi-Way 0 4th March 2004 11:17 AM
Subwoofer to Regular speakers Jeremy Subwoofers 1 15th January 2002 02:34 AM
Copyright ©1999-2019 diyAudio
