SynTripP: 2-way 2-part Virtual Single Point Source Horn
Thread Tools
Old 14th September 2021, 12:08 PM   #881
pelanj is offline pelanj  Czech Republic
Nice. What cutting tools are you using? And how do you cut the compound angles? I have done only 2.5D and some simple 3D on my CNC router. All g-code is made in F360? And the alignment? I would really appreciate some tips on how to make such an advanced project for my CNC. I would mostly need some tips on which tools and which machining strategies to use for the compound angles, that would really help me move forward. Pointing to a tutorial would be great, too. I use Estlcam and CamBam now, might try F360 for CAM as well.
Old 14th September 2021, 06:53 PM   #882
Pyronious is offline Pyronious
The compound angles on the lower horn were a bit of a trick to work out a good solution for. I ended up using a tapered bit (specs in attached screenshot) and a 3D contour toolpath.
The design also requires that the parts be machined from two sides, as the tapers don't all face the same side of the stock. I drill 1/4" registration holes through the stock on side A and machine that side. Then flip the panel over, register the part using 1/4" pins, and machine side B.
This was actually the first time I've done a two-sided CNC project, so it was a great opportunity learn how to approach the process.
Old 14th September 2021, 07:47 PM   #883
Thanks. I will check that bit out. Do you think I could make some more simple angles (like for example for a petal horn) with a ball mill? I must say, If I have not already, your work is really impressive!
Old 14th September 2021, 08:28 PM   #884
Yes, I think a standard ball mill would be totally acceptable for this kind of work, as long as you don't have multiple tapers coming together and meeting at an angle less than 180 degrees (at which point the quality of the seam between them would be limited by the radius of the ball mill).
Old 14th September 2021, 09:05 PM   #885
Domz732 is offline Domz732
Thanks again Art
Old 15th September 2021, 07:00 AM   #886
Got the cone filler carved today. In another slight departure from the baseline design, I made the filler disc a bit thicker (it comes in at 1.2 inches tall). The profile conforms more closely to the measured profile of the LF driver cone, while still leaving the required gap for full cone excursion.
The section view in Fusion360 was really helpful when working on this feature. The screen shot below shows an approximation of the speaker cone; the cone filler disc is based on the cone measurements posted by Jennygirl in this thread.
The journey continues...
  Reply to this post
SynTripP: 2-way 2-part Virtual Single Point Source HornHide this!Advertise here!
Thread Tools
Battery power amp has virtual earth point(+13v?). bi ampable with mains grounded amp? duckanddexter Power Supplies 4 8th April 2014 07:29 PM
Offset parabolic reflector w virtual point source behind enclosure??? kenpeter Multi-Way 1 9th October 2009 01:10 PM
Single Supply LM3886 - better virtual ground turantual Chip Amps 2 8th August 2008 08:39 AM
Virtual instruments from USB source jackinnj Parts 15 17th May 2007 03:59 AM
Battery PS: Virtual ground or single supply? Dominique Power Supplies 2 5th May 2007 11:34 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
