SynTripP: 2-way 2-part Virtual Single Point Source Horn
Old 14th March 2019, 01:48 AM   #761
Flaesh is offline Flaesh  Russian Federation
Flaesh's Avatar
Originally Posted by Laaker View Post
.. I've used the 18 sound HD1480T HF Compression driver.
Finally I found someone using©AdamFelix 18 sound HD1480T.
What can you say about this driver?..
flesh flash flush
Old 14th March 2019, 08:24 AM   #762
AdamFelix is offline AdamFelix  Denmark
Thanks Art!
If I want the loudspeaker to go lower than 82 hz, would that be possible with different 10 inch drivers? If yes, what parameters should I be looking for? The link you posted had some broken links, so I don’t know if I missed something important.
Old 14th March 2019, 09:37 AM   #763
Laaker is offline Laaker
@ Flash, I haven't done any measurements of the 18 sounds in the syntripps yet. To my wooden ears they sound smooth in the syntripps. Maybe little EQ may be necessary in the upper frequencies. Distortions were low even at very high levels (crossed at 920Hz). I used only -6dB for them in the DSP setting and calibrated thier volume on the Volume knob of the amp. I didn't want to rip the people heads of. Very high spl. I think more than -12 dB are necessary to level them to the mids. Beware! They are heavy. Propper mounting is requried.
Christian
Old 14th March 2019, 12:34 PM   #764
Flaesh's Avatar
Thanks Christian. Have you compared hd1480t with others, may be subjectively?
Measurement below 1k and above 10k are interesting also. If and when
flesh flash flush
Old 14th March 2019, 03:37 PM   #765
weltersys is offline weltersys  United States
weltersys's Avatar
Originally Posted by AdamFelix View Post
Thanks Art!
If you want your Fb loudspeaker to go lower than 82 Hz, the tuning(Fb) would also need to be lowered. Fb should be equal to or above Fs for maximum sensitivity.
Horn loading generally requires high Bl (motor strength) and high output requires high Xmax. Easy lifting requires light weight, neodymium magnets provide light weight and high Bl.
Old 14th March 2019, 06:53 PM   #766
1hiep0 is offline 1hiep0  United States
Art,
How thick is the TAP if I use 1" exit driver? Anyway it's for home use. Thanks,
Old 14th March 2019, 07:19 PM   #767
weltersys's Avatar
No idea what you mean by "TAP".
Post #41 contains plans, Post #61 has the completed parts lists and assembly instructions, Post #100 has photos of the bass reflex port details, Post #115 has the throat port detail. Posts #128,138, & 568 have injection port and cone filler details.
Old 14th March 2019, 07:27 PM   #768
Throat Adapter Plate
Old 19th March 2019, 02:49 AM   #769
MrSpeakers is offline MrSpeakers  United States
MrSpeakers's Avatar
@welterys thanks so much for sharing what looks like an amazing project. I'm another SoCal Burning Man enthusiast, and am planning to use this as the basis for a system to bring to playa this year, and our local San Diego Youtopia festival in October.
We're rather lazy woodworkers and don't have a CNC router, so we're going to do this on our big laser, using only right angles for most construction and making joiners on 3D printers.
We'll probably do the drawings in Solidworks, and will share the files with anyone interested in personal projects if it all works out.
One question; did you finish assessing the DE90TN?
Cheers!
Dan
Old 21st March 2019, 11:37 AM   #770
6NS is offline 6NS  Thailand
Yes, I've been watching for the DE90TN implimented with his horn as well.
Sounds like an overall winner when completed.
I myself can't vision how the DE90TN is housed and attached.
I'll be watching Art, thanks so much.
SynTripP: 2-way 2-part Virtual Single Point Source HornHide this!Advertise here!
Battery power amp has virtual earth point(+13v?). bi ampable with mains grounded amp? duckanddexter Power Supplies 4 8th April 2014 07:29 PM
Offset parabolic reflector w virtual point source behind enclosure??? kenpeter Multi-Way 1 9th October 2009 01:10 PM
Single Supply LM3886 - better virtual ground turantual Chip Amps 2 8th August 2008 08:39 AM
Virtual instruments from USB source jackinnj Parts 15 17th May 2007 03:59 AM
Battery PS: Virtual ground or single supply? Dominique Power Supplies 2 5th May 2007 11:34 PM
Copyright ©1999-2019 diyAudio
