SynTripP: 2-way 2-part Virtual Single Point Source Horn
Old 13th September 2018, 04:00 AM   #741
ellisr63 is offline ellisr63  Mexico
Is there anyone that could/would be willing to make a CNC file? I really want to make some of these, and this would be the best way for me , and others to get the best results.I do not have a place to cut the pieces, but I can get them cut locally via CNC.
9 DIY B&O Bridged amps for biamped horns, Yamaha cxa5100 preamp, Oppo 203, Samsung 65" 4k fp, KLH sub. DIY projects... 7 horns with 3 being DIY Synergy horns for living room.theater
Old 14th September 2018, 06:11 PM   #742
A CAD file would even work... I would like to get started ASAP on these for our home theater. I was going to use the 2384s, but the shipping costs plus duty were very high. I think I can build the complete speaker for less than buying, and shipping the 2384 alone.
Old 14th September 2018, 07:50 PM   #743
weltersys is offline weltersys  United States
weltersys's Avatar
So would a DIY woodworker with a table saw and the cut list ;^).
Art
Old 14th September 2018, 08:08 PM   #744
Yes, but I had to sell my saws when we moved, and I want to be able to give the carpenter the best measurements and directions possible. I have seen their work on furniture, but I do not know how goid they will be trying to figure out the angle of cuts. I hate to give a job to a carpenter, and have the cuts be iff because they missunderstood the directions. I know..that is my problem on who I pick, but the best ones I can go to do CNC.
I am willing to pay for for the plans (if I can afford it)so everyone on here can use them if you will allow it.
Old 14th September 2018, 09:08 PM   #745
Zwiller is offline Zwiller  United States
There is a file but it is not finished. I recall the design needs to be deepened slightly to fix some angles off a tenth of a degree so it can CNC much easier. Not my work. I have some really neat ideas if the file does get finished.
_____________________
Sam
Old 14th September 2018, 10:10 PM   #746
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
I have been a cabinetmaker for many many years.
The best ones will make what you ask for. And do it exactly.
If you want to perform a test of the shops skill level may I suggest this simple sounding test.
Ask for a pyramid. You specify the base dimensions and the height dimension. Ask for the joinery to be as good on the interior of this hollow pyramid as they make it on the exterior.
I once worked for the national museum in Ottawa Canada doing architectural reproduction work. Period doors and window, as well as fine furnishings. The test I described was their entrance into the shop test. It is a true test of the craftsmanship of the people doing the work.
P.S.
No CNC was allowed in that shop. It was calculate cut and measure.
Mark
www.kravchenko-audio.com
Old 14th September 2018, 10:35 PM   #747
Thanks, I will see if they can make me a pyramid...now if someone could just finish off the plans.
Old 15th September 2018, 05:12 PM   #748
weltersys's Avatar
Post #41 contains the plans used to build the SynTripP, and a preliminary parts lists. Post #61 has the completed parts lists and assembly instructions, Post #100 has photos of the bass reflex port details, Post #115 has the throat port detail. Posts #128,138, & 568 have injection port and cone filler details.
I advise anyone building to loft their own full size plans to make accurate parts comparisons easy, and to account for any slight material thickness differences encountered.
Art
Old 17th September 2018, 07:55 AM   #749
FinBot is offline FinBot  Australia
FinBot's Avatar
Originally Posted by Kaironex View Post
Thanks Art,
I'll mostly be playing sound for recorded music, Psytrance, Techno, DnB so some haystacking on the subs won't be unwanted.
I'll be aiming for the 5" taller keystones too for abit lower extension, probably with a HD215 style kickbin above the keystones, all my events are outdoors with chances of random rain coming through the duration of the event, which is why I prefer to go horn loaded and angled down slightly over linearray for weather protection, the keystones with the extenders+mesh and acoustically transparent screen over the mouth sold me for performance to pack size ratio while being weather resistant. the size and performance of the SynTripP's is also why im leaning towards them as I dont have unlimited pack room.
Kai.
Dude im in Melbourne. You could have a play with mine sometime. I have four. Horse Bizzar also has a pair from my build plus two keystones. So you can hear them in action.
Old 17th September 2018, 08:10 AM   #750
FinBot's Avatar
Originally Posted by rsheptak View Post
I'd love to build a set of SynTripP's but it seems the compression driver, the Celestion CDX14-3050, has gone out of production and is no longer available from US suppliers. Is there a blessed substitute? Anyone working on a substitute? Thanks.
rus
So long as you select one that can handle 500hz and up, it will work.
I think each one will have its own coloration, so you just pick one and work with it.
Our future plan is to fit the BMS Coaxial drivers. If you can afford it, do it. (with a back door modification to fit it plus the passive xo)
SynTripP: 2-way 2-part Virtual Single Point Source HornHide this!Advertise here!
Battery power amp has virtual earth point(+13v?). bi ampable with mains grounded amp? duckanddexter Power Supplies 4 8th April 2014 08:29 PM
Offset parabolic reflector w virtual point source behind enclosure??? kenpeter Multi-Way 1 9th October 2009 02:10 PM
Single Supply LM3886 - better virtual ground turantual Chip Amps 2 8th August 2008 09:39 AM
Virtual instruments from USB source jackinnj Parts 15 17th May 2007 04:59 AM
Battery PS: Virtual ground or single supply? Dominique Power Supplies 2 6th May 2007 12:34 AM
Copyright ©1999-2019 diyAudio
