Parallel Seas Loki II - how to modify crossover?
Thread Tools
Old 19th October 2014, 06:10 PM   #1
DrG is offline DrG  South Africa
Default Parallel Seas Loki II - how to modify crossover?
Hi all.
I'm considering building the Seas Loki II kit (Madisound) but perhaps with 2 drivers paralleled per unit. The standard crossover is as per attached picture.
My understanding is that halving the impedance means inductors in the crossover circuit must be halved also, while capacitors must be doubled.
First question: is this principle correct?
Second question, what about the series 2R7 and parallel 8R2 resistors in the tweeter circuit? What do I do with those?
Sheldon
Old 19th October 2014, 09:43 PM   #2
dukanvadet is offline dukanvadet
You will get lobing issues and the baffle size affects frequency response. It seems easier and better to get a kit that you are happy with without modification.
Old 20th October 2014, 10:41 AM   #3
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
Here is a Finnish kit that adds a P18 woofer to the same coaxial T18 By SEAS.
Aw-36X rakennussarja - Hifitalo The configuration is 2.5, the woofer has an extra coil and is in series with the coaxial woofer. Sorry but I donät have the schematics.
Description Aw-36X rakennussarja - Hifitalo
Enclosure (separate chambers with different tuning)
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
Haku - Hifitalo[1].pdf
By the way I like my T18s very much in sealed 9 liter box. In a small room it gives very solid and clean bass. I have also a 2x15" subwoofer for movies.
Radikal aktivist AINOgradient speaker project
Old 20th October 2014, 02:05 PM   #4
Thanks Juhazi, I'll look into this. It's more along the lines of what i have in mind.
Very much appreciated.
Sheldon
  Reply to this post
Parallel Seas Loki II - how to modify crossover?Hide this!Advertise here!
Thread Tools
FS: Seas Loki Drivers and crossovers Spev Swap Meet 8 16th April 2013 05:49 PM
For Sale: SEAS Loki MKII, Madisound kit, 2-way coaxial - $500 Electro3000 Swap Meet 4 24th October 2012 09:50 PM
Need your advice to modify crossover. floatingfloc Multi-Way 30 25th June 2012 03:01 PM
Modify MTX crossover ? ? poopydoopynoopy Analog Line Level 1 12th September 2010 03:32 AM
Seas Loki crossover spendorspain Multi-Way 7 26th March 2007 05:30 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
