Attaching flexible leads to aluminum voice coil wires
Old 8th September 2014, 05:26 AM   #1
cyclecamper is offline cyclecamper  United States
Default Attaching flexible leads to aluminum voice coil wires
I know that with the correct materials, equipment, and technique, aluminum can be welded, brazed, and even soldered. There are simpler techniques for plating and soldering the wire ends. There are conductive glues.
What do speaker mfgrs ike JBL use to electrically connect & attach flexile leads to a cone with flat edgewound aluminum wire voice coils?
Old 8th September 2014, 06:17 AM   #2
VaNarn is offline VaNarn  Australia
The preferred method requires an ultrasonic solder pot to pre tin the aluminium wires which allows for the use of normal solders.Otherwise there are special solder alloys and fluxes such as Alu-Sol from Multicore that can be used,although some experience is needed to find the best technique to make reliable connections.
Attaching flexible leads to aluminum voice coil wiresHide this!Advertise here!
Aluminum vs. copper voice coil wire? capslock Multi-Way 8 23rd October 2016 05:47 AM
Aluminum voice coil former glue? s3tup Multi-Way 4 14th April 2010 02:00 PM
Voice Coil Formers... Kapton vs Nomex vs Aluminum vs GF/TIL OlogyAudio Multi-Way 3 1st June 2007 02:27 AM
Single Voice Coil Vs Double Voice Coil Subwoofer kASD Car Audio 6 12th April 2007 06:36 AM
glue for voice coil wires malcontent Multi-Way 5 6th March 2007 01:12 AM
Copyright ©1999-2019 diyAudio
