Surround less, spider less, mid bass driver
Old 4th July 2014, 02:25 AM   #11
CLS is offline CLS  Taiwan
I don't get it, either.
When the stroke is larger than a certain degree, the cone should be suspended at least at 2 positions to maintain the axial motion. That supresses the possible rocking to a minimum. And that degree of stroke might be still pretty small, I guess.
The suspensions should provide compliance and damping in a linear (or preditable) way. One of them should be air tight as the cone.
Er... those are just driver 101. Sorry.
So I can't visualise a successful driver without surround. Unless it's a whizzer cone and we ignore all other parts.
I vaguely remember, years ago, there's a Japanese big company providing products of surround-less woofer(s) on their high end boombox (or the likes). It's working like a sliding piston in a cylinder. And it was even promoted by its ability of long stroke. (small diameter, that is)
Now I can't even find it on google.
Old 4th July 2014, 02:35 AM   #12
Andrew Eckhardt is offline Andrew Eckhardt  United States
Unfortunately the surround does more than suspend. It also damps bell mode resonance. Multiple parallel driven coils at the perimeter (in addition to apex coil) would be better. The logical end of progression would be a massively arrayed setup with a small drive coils/EM suspension/and cone areas. At that point you'd find that it isn't necessary to have them all totally isolated. A segmented radiating area with high damping links between them would be enough, or better, depending on how you wanna look at it...
Old 4th July 2014, 02:39 AM   #13
R.I.P.
Us old farts know nothing, go with the clueless enthusiasts.
The outer aluminium ring is very poor cone termination,
it will work for bass, but won't work for good midrange.
Its telling the driver is always shown horizontal, its
obvious it won't work well vertical, as it has to.
Ferrofluid has been tried in bass units and it doesn't work,
and that is fitted with standard surrounds and spiders.
Any driver needing a separate supply needs to be great
to succeed, with no issues, I really can't see that here.
FWIW the issues of interaction of magnetic and suspension
linearity have been well covered previously, so here all you
are getting is a claim of an offering of something ideal.
Something us old farts have seen a lot of in our time,
different, unless really good, hardly ever means better.
rgds, sreten.
Not that I'm that old, but I might as well be.
Old 4th July 2014, 02:41 AM   #14
IG81 is offline IG81  Canada
IG81's Avatar
Fostex "edge-less" woofer perhaps?
https://www.google.ca/search?site=&s...30.bPdNvzGp_IQ
Old 4th July 2014, 03:13 AM   #15
R.I.P.
Said boombox used a long voice coil former with two back
to back spiders for linearity and a "surroundless" cone
on one end and a typical magnet system the other.
The edge of the cone had a quadrant section which very much
looked like white felt to me, that skimmed the cylinder it was in.
Fine for bass, rubbish higher up, but it was a sub.
5" (effectively bigger) in a 6" tube about 20" long I recall.
I also recall 4th order bandpass and a window
where you could see the gubbins of the driver.
rgds, sreten.
Old 4th July 2014, 03:34 AM   #16
Inductor is offline Inductor  Portugal
Inductor's Avatar
Nice. Congratulations, the first step is the more important. Hope you stay in business... after a few years (already two for the count/development.) Is it a FR(extended range)? Is it possible to post a complete set of T/S parameters (maybe later in time) with freq. output curves. Patents are very expensive (price and layers) and only interesting if someone is producing them (factory/speakers drivers) or licensing the technology. I bet all the good manufacturers like B&W, B&O and others are interested. You can start with trademarks today, they are very cheap comparing.
It makes me think of Romy the Cat with the Mitsubishi Diatone P-610 and leather suspensions and the Atelier Rullit (some links below, please feel free to compare them, goods and bads.)
Atelier Rullit
http://www.analog-forum.de/wbboard/b...er-gebraucher/
DIATONE ƒXƒs[ƒJ[ƒ†ƒjƒbƒgˆę—— ƒ_ƒCƒ„ƒg[ƒ“ ƒ_ƒCƒAƒg[ƒ“
GoodSoundClub - Romy the Cat's Audio Site - Forget the Diatone ? the leather suspension is the key interest.
Old 4th July 2014, 03:54 AM   #17
jcarr is offline jcarr  United States
Pioneer made what it called "edge-less" woofer units, such as the one used in the S-LH5 here:
Pioneer S-LH5
hth, jonathan carr
http://www.lyraconnoisseur.com/, http://www.lyraaudio.com
Old 4th July 2014, 04:24 AM   #18
thoriated is offline thoriated  United States
The problem I've heard with ferrofluid in bass drivers is that it tends to be thrown out of the gap during long excursions with high accelerations. Ferrofluid may work better in an underhung VC configuration where it has less opportunity to 'escape'.
Art is nothing without science; science is nothing without philosophy.
Old 4th July 2014, 07:03 AM   #19
Jef Nuyts is offline Jef Nuyts  Belgium
@ indicator
Very interesting of what you say about trademarks. I will take a close look at it.
I will this evening reply to the other questions.
Take care
Old 4th July 2014, 10:00 AM   #20
Inductor's Avatar
Take care.
Surround less, spider less, mid bass driverHide this!Advertise here!
Choosing a driver for an OpenBafle mid-bass Eldam Multi-Way 13 23rd May 2014 11:32 AM
What Bass/Mid-bass driver for me? timreeves Multi-Way 4 17th March 2011 01:09 AM
Best driver for Mid Bass SETorbust Multi-Way 6 26th February 2011 06:57 PM
in need of recommendation for a mid-bass driver piro Multi-Way 4 4th June 2004 09:06 AM
Spider and surround creep capslock Multi-Way 1 30th November 2002 01:33 PM
Copyright ©1999-2019 diyAudio
