Contemplating speaker building
Old 27th February 2014, 07:59 AM   #11
Top Shelf is offline Top Shelf  Canada
Top Shelf's Avatar
I say go for the 15" plus mid and tweet. Nothing is more annoying than having speakers that just barf and fart when you crank it. Maybe try a 15" operating from 30-100 hz then a real fullrange type 6" or 7" driver to handle 100- 4500 hz, finally a compression driver /horn combo to fill out the top end. Im on my way to doing this myself for my main speakers in the livingroom. One thing though, give them a real nice finish on the cabinets. That way you can be proud of it as a whole not just on the sound. But thats just my 2 cents. Hope you succeed and enjoy whatever you build for years to come........until you get the "itch" again
NO REST FOR THE WOOFER! 🔊😈
Old 27th February 2014, 02:13 PM   #12
Raccoon1400 is offline Raccoon1400  Canada
Raccoon1400's Avatar
That's what I'm thinking, and I'd definitely use the 6" mid. One interesting speaker design I saw was the electrovoice interface D. A downfiring 12" woofer, a 6" ported mid, and a wide dispersion horn tweeter.
I'm thinking I'll start with something smaller though, work a couple kinks out and get the hang of the process with a two way bookshelf.
Also, for materials, everything I read so far says MDF is the way to go. I've been talking to my friend, who is also into audio, and has a lot of woodwork experience. He thinks something like 11 layer birch ply would have less resonance, and that this is the way to go.
Old 28th February 2014, 03:36 AM   #13
Top Shelf's Avatar
Oh no. You've gone and done it. I forsee a cabinet materials "debate" coming
Old 28th February 2014, 03:50 AM   #14
Top Shelf's Avatar
You could try a side firing 12", which would make the base area smaller as well as the frontal, and eliminate cone sagging.
A two way bookshelf is a great place to start. Tons of examples round here. Somehow i can't upload pictures on this site so this image is on dropbox. Its of my studio monitors im working on. https://db.tt/wcKzm8iH
Old 28th February 2014, 03:54 AM   #15
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
Very nice !
Old 28th February 2014, 02:32 PM   #16
I did some searching on this and read the debate. I'm new here so I don't know what topics are cans of worms. I'd have edited that part out after searching if I could edit my posts.
Old 28th February 2014, 06:27 PM   #17
Top Shelf's Avatar
Ahhh just pulling your leg
Old 28th February 2014, 07:06 PM   #18
Greebster is offline Greebster  United States
Greebster's Avatar
Baltic Birch is better and far more durable. MDF is prone to issues with expansion and moisture. Not the most stable material for the long haul. Primed and sealed up can help prevent these issues. There are threads where all this is contested, blah blah blah
Old 28th February 2014, 10:05 PM   #19
The impression I got is both take different construction techniques to get the most out of them, and work with their strengths and weaknesses. Maybe Birch was liked a bit more, but I'll make up my own mind after much more reading.
EDIT: nice, first post that didn't have to be approved by a mod. And I can edit it!
Last edited by Raccoon1400; 28th February 2014 at 10:07 PM. Reason: Because I can!
Contemplating speaker buildingHide this!Advertise here!
Contemplating a budget MTM project using full/extended range speakers goldorak Full Range 17 27th February 2014 04:40 PM
Contemplating First Full Range Build. Suggestions? Xaborus Full Range 44 4th October 2013 07:12 PM
Need some help building my first speaker, please! ahl395 Construction Tips 4 6th November 2010 08:01 PM
Contemplating the Saburo- opinions please strider75 Full Range 7 29th April 2008 09:24 PM
Contemplating This Fostex Fe127 Project JimOfOakCreek Full Range 18 20th March 2008 02:13 PM
Copyright ©1999-2019 diyAudio
