Scanspeak Revelator 32W/4878T00 13" Bass Driver
Old 8th July 2018, 09:13 AM   #21
Melkior is offline Melkior  France
Hello Wolf, thanks a lot for your answer.
I'll go for a 15 cm scan speak.
My choice for the tweeter was just driven by 20 years of listening, Scan speak are the only ones that goes high enough without hurting my ears. I have had Gamut Speakers (L5 and L7, based on 18 cm scan peak revelator woofers + scan speak tweeter R2904/700005), Sonus Faber Elipsa and Stradivari (medium 15 cm modified scan speak classic serie + scan speak tweeter R2904/700009). The D3004/66200 has a very nice frequency response curve so I said why not, but I could use also the R2904 as it has been used in previous speakers with 18 and 15 cm mid without problems.
I agree that a 15 cm would be more consistent in terms of crossover possibilities, mainly if I use the two 26W/4558, as they can be crossed at 300-400Hz.
Old 3rd December 2018, 10:39 PM   #22
darkmatter is offline darkmatter  United Kingdom
darkmatter's Avatar
Originally Posted by Melkior View Post
I'm going to start my project :-)
A last question before ordering,
Config : 1 expensive
Tweeter Scan speak D3004/66200
Mid Scan speak 18M/8631
Sub Scan speak 32W/8878 (Closed enclosure 113 liters Qtc = 0.577)
Config : 2 cheaper , bus as good as ?
Mid Scan speak 18W/8542
Sub Scan speak 2x26W/4558 (Closed enclosure 77 liters Qtc = 0.577)
Crossover at 200 HZ and 1500 Hz
How did you get on?
The 32W config 1 project is of interest
Old 12th January 2019, 11:08 AM   #23
Hello,
Well project in stand by, but not canceled. I wanted to make speakers more or less like Dalhquist, with a closed box for the bass unit and medium + tweeter on an open baffle on top of the sub. A friend of mine did one pair and it's impressive. Basically my only problem is which kind of medium unit can be used on a small open baffle, I thing it does not matter for the tweeter, but on the medium yes, I've found nothing concerning the datas to check for the possibilities of using a driver on an open baffle.
And still not decided to get a 32W/8878 (or 4878) or two 26W/4558. The 26' are certainly of a lower quality , but will be certainly more quickly responsive, and allows to use a 12MU instead of a 18M or 18W, with would be better for a clean mid range and tweeter coupling.
I've a small company I have to care with and 2018 has been a good year, so I'm able to start the project now.
Scanspeak Revelator 32W/4878T00 13" Bass DriverHide this!Advertise here!
WTB scanspeak revelator pjblakey Swap Meet 1 3rd November 2013 10:24 AM
Scanspeak 26w/8861 T00 10" Revelator woofer pair anthony6870hifi Swap Meet 5 3rd May 2012 03:09 AM
ScanSpeak Revelator 18W/4531G 7" Woofer for sale Geardaddy Swap Meet 0 3rd October 2011 04:11 PM
2 ScanSpeak 12M/4631G00 4 1/2 Revelator Midranges" Daytona50 Swap Meet 1 18th December 2008 07:51 PM
Scanspeak Revelator 99000 (used) tomat Swap Meet 1 25th August 2008 12:54 AM
Copyright ©1999-2019 diyAudio
