JBL M2 for The Poors
Thread Tools
Old 17th January 2019, 11:12 PM   #591
plasnu is offline plasnu  United States
Patrick, I finally concluded that JBL waveguides are NOT an improved version of their horns after listening to JBL horns/waveguide for 2 years. Those JBL waveguides have very little relationship to their previously designed horns, culturally, philosophically, nor technically.
I strongly believe that those new JBL waveguides were designed by a person who dislikes the sound of horn, for people who dislike the sound of horn, and they do not sound like a horn indeed. Still, they do sound like a compression driver, though.
Old 17th February 2019, 05:00 PM   #592
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
Originally Posted by Patrick Bateman View Post
I made something similar to the JBL Image Control Waveguide. I set the size so that it's footprint would be identical to the Elliptical Oblate Spheroidal waveguide from yesterday. From the side, they look similar...
From above, you can see the "beaks"
The model in ABEC
I thought this graph is REALLY interesting : though the footprint is *identical* to the EOS waveguide, the beamwidth is about 20-30% wider! Very interesting. Now I see why JBL stated that the I.C. Waveguide allowed them to cram a compression driver into an in-wall speaker.
Here's the output on axis. Above 4khz, the I.C. waveguide has more output than the E.O.S. waveguide. I believe that this is because the ICW is radiating into a narrower angle, and therefor the output level rises. This waveguide is a study in contradictions: on-axis, it's radiating into a narrower angle, raising output. Somehow, directivity is *wider* than a EOS waveguide. I assume this has something to do with the diagonal diffraction slots.
The obvious thing to do is blend the two and get a compromise between both: the smooth polars of the EOS with the wider directivity of the ICW.
footnote: if you look at the graph of the EOS response from yesterday, and the ICW response from today, the latter looks "lumpier." Part of the reason for this is that I doubled the resolution of the sim. As I understand it, ABEC only simulates at the frequencies that you tell it to simulate. IE, if you tell it to simulate eight frequencies, that's all you get; everything else is interpolated. So I cranked up the resolution on today's sim to 64 frequencies, whereas yesterday's was only 32. My laptop only has four cores, so I'll need to set up a proper desktop so that I can start doing sims with 100+ frequencies.
I'm doing a call back to a previous post, because I've been doing some more sims of something similar to an Image Control Waveguide
Old 17th February 2019, 06:40 PM   #593
I'll cut to the chase. My sims seem to show two things:
1) The horizontal diffraction slots of the JBL ICW seems to outperform the vertical diffraction slots of a conventional diffraction horn.
2) The sims seem to indicate that the larger your waveguide is, the worse it performs. This is something I've long noticed, anecdotally, so it really requires some research. On the forums, a few people have noted that the much less expensive JBL LSRs sound competitive with the much larger and more expensive M2s. Some have speculated that the difference is the compression driver, but perhaps the difference is simply the waveguide.
Here's a sim of a 'conventional' waveguide with a diffraction slot, similar to the 18Sound XT1086. The performance isn't great, and I think the issue is that the diffraction slot is screwing up the pathlengths. In the ABEC sim, note how lobes start to appear as low as 2500Hz, and the lobes become more severe at higher frequencies. Geddes has done a ton of research on diffraction slots, and has argued that the discontinuity in the slot creates higher order modes. This ABEC sim seems to show that the diffraction slot also creates comb filtering due to the pathlength differences caused by the slot. If you look at a diffraction waveguide as two segments, there is a diffraction slot that 'feeds' the larger waveguide bell. For the waveguide to work properly, it must be fed with a wavefront that matches. For instance, if the 'bell' of your diffraction waveguide measures 120 degrees by 60 degrees, then the wavefront that exits the diffraction slot must match that, or you're going to get discontinuity.
I threw together this pic to illustrate what I mean. In the pic, note how there's a mismatch between the wavefront shapes on the vertical and the horizontal. The mismatch is due to the varying pathlengths.
Basically there only seems to be a couple of ideal solutions here:
1) You could drive the waveguide bell with a ribbon. But this isn't a perfect solution, because the ribbon isn't a perfect match for the waveguide. But it might be better than a compression driver because...
2) If you use a compression driver, you are probably going to have astigmatism. Basically the wavefront that exits the diffraction slot will be bent on the vertical axis but mostly flat on the horizontal axis.
I think that if one had a LOT of time to kill, they could probably make about a hundred different combinations of diffraction slot and waveguide bell and you could probably come up with something that works halfway decent. Of course, this would only work for a single compression driver, because I haven't even touched on the fact that the phase plug of the compression driver itself will alter the results of this!
Old 20th February 2019, 03:18 AM   #594
whgeiger is offline whgeiger  United States
Default When designing horns
avoid discontinuities in the second derivative of the of the curves, both longitudinal and transverse, that define all horn boundaries. This tack should minimize the horn artifacts otherwise attributable to its size and geomerty. WHG
Old 25th February 2019, 09:32 PM   #595
Thank you! Agree 100%
Old 25th February 2019, 09:35 PM   #596
I noticed something interesting today: the patents on ring radiator compression drivers expire today.
Also, I never realized that Alex Voishvillo, the same person who worked on the JBL dual diaphragm compression drivers, was also the one who patented the *original* annular compression drivers. Oddly enough, the patent is when he was at Cerwin Vega?! But the patent owner is BMS (of course.)
Here's the history:
1998-09-25
Priority to US16155498A
1999-09-16
Application filed by Eugene J. Czerwinski, Alexander G. Voishvillo
1999-09-16
Priority to US09/397,407
2001-08-15
Priority claimed from US09/930,565
2001-11-20
Application granted
2001-11-20
Publication of US6320970B1
2018-09-25
Anticipated expiration
2019-02-25
Application status is Expired - Fee Related
Old 25th February 2019, 10:25 PM   #597
ScottG is offline ScottG  United States
But this poses a technical problem; if the wavefronts literally can't "see" the walls, what's the point of the waveguide?!
..On the downside, I've only scratched the surface of this phenomenon. This is a complex problem and there's a million factors that will influence the behavior of the unit:
1) The diameter of the tweeter is going to have a huge impact here. A 1" tweeter is beaming above 13.5khz. So right out of the gate, about 25% of the tweeter's bandwidth will be unaffected by the waveguide, because the diaphragm is beaming.
-it's still affecting it, right?
It's just not affecting it AS MUCH. In other words the amplitude is substantially lower in level than the average - there just isn't as much gain to be derived from "squashing" the polar coverage.. and of course even what gain is derived, is lost (you traded it) as you move even further off-axis.
So why do it? (for the tweeter and its full bandwidth)
1. Gain with identical excursion - increases power handling and at the previous spl-average: lowers non-linear distortion; OR it allows for increased lower freq. bandwidth for a similar amount of excursion/distortion.
2. Often easier to mitigate cabinet diffraction artifacts over a particular bandwidth.
3. Can allow for better directivity matching to midrange driver.
4. Offers acoustic "delay" relative to midrange.
5. (combination of 1-4): usually makes crossover-work easier in a number of respects.
-I think the biggest problem is that you often have to "cut into" the waveguide for tighter spacing with the midrange driver (..and just accept even a well done "cut-in" increasing diffraction and other artifacts related to the midrange.)
-btw, this thread has gotten very nice! (..I'm off to give it more stars.. and at only 6 votes including mine - it didn't budge it.. bummer.)
perspective is everything
Old 25th February 2019, 11:02 PM   #598
kipman725 is offline kipman725  United Kingdom
Overly Enthusiastic
kipman725's Avatar
JBL M2 for The Poors Send a message via MSN to kipman725
So higher efficiency compression drivers for high frequencies soon?
Old 26th February 2019, 01:00 AM   #599
DCX....launching soon. Stay tuned. - B&C Speakers SpA | Facebook
I'm betting we'll be seeing more ring radiators from competing manufacturers soon. Maybe if we're lucky, Tymphany or Celestion will get in on this, they offer a lot of bang for the buck.
Old 26th February 2019, 01:45 AM   #600
Flaesh is offline Flaesh  Russian Federation
Flaesh's Avatar
Small ring B&C Speakers
And funny 4" coax B&C Speakers
JBL M2 for The PoorsHide this!Advertise here!
Thread Tools
First Watt M2 Kovax Pass Labs 154 13th February 2014 05:20 PM
New JBL Monitor, M2 ...why so many Watts required? Richard Ellis Everything Else 8 19th October 2013 06:12 PM
JBL m2 ! Ahmad_tbp Multi-Way 0 7th February 2013 01:14 PM
Sale: JBL 16" K145, JBL 8" 2118, JBL 2404 HF, Fane ST-5022 (Edgarhorn), Klipsch K55V ZERO1 Swap Meet 3 3rd February 2013 11:03 PM
First Watt M2 chrismercurio Pass Labs 16 18th March 2012 01:53 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
