Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Multi-Way Conventional loudspeakers with crossovers |
Enjoyed today...fitting the pristine Tannoy Monitor Reds. Initially, had a glitch with a hook up wire...but removed driver and tested...all good.
On hand, Weston Acoustics 2A3 SET, Leak 20 watt Class A, and a small digital amp. The sound was very good...more laid back to the big Altecs I have...but very balanced and detailed. You could listen to these all day, easy. The cabinet seems to be working well with the bass...not humps, chuffing etc. Bass depth is good, even with SET amp. Euro birch ply used, with lovely Sydney Blue Gum veneer. 150 liter internal volume, sturdy bracing added. Need to build the plinths and add front trim, then ship off for two pack poly gloss spray. A busy but enjoyable weekend.... |
#2 |
looking very nice, simple and "nostalgic"
![]() i bet they sound as they look Danny |
Thread | Thread Starter | Forum | Replies | Last Post |
Tannoy Monitor Red Crossover questions | glenz75 | Full Range | 1 | 13th January 2012 05:14 PM |
Tannoy Monitor Red Response? | Tenson | Multi-Way | 0 | 27th August 2010 03:48 PM |
Tannoy monitor RED 12'' cabinet | marin_iskra | Full Range | 4 | 11th November 2008 10:51 PM |
Single Tannoy monitor red as a sub? | Brisso57 | Subwoofers | 6 | 29th September 2008 05:40 PM |
Single Tannoy monitor red as a sub? | Brisso57 | Full Range | 0 | 28th September 2008 02:21 AM |
New To Site? | Need Help? |
