I've been modding and restoring a set of dittons. Since last re soldering everything there is less bass from one side, mainly the sub end of things. I swapped the woofer so it points to being the crossover as it remained on the same side.
Does anyone have any idea what it would be? Am I somehow making a hpf somewhere?
I don't know, not really if you're talking about the lowest bass and it's just a 2nd order lowpass, which is what I imagined. Maybe start with disconnecting the whole crossover, just running the woofers alone wide open in each, A/B that and see what you get. Also swap amp/pre/etc. channels, just in case, if that's not already ruled out.
You have these speakers in pretty much the same location, not like opposite corners of a room, right?
- Less bass from crossover
