System Pictures & Description
Old 26th May 2020, 10:53 AM   #3331
MatsS64 is offline MatsS64  Russian Federation
Speaker circuit.
Old 31st May 2020, 11:52 AM   #3332
6thplanet is offline 6thplanet  United States
6thplanet's Avatar
Nice work, GeeVee! For a first time go, you really went all out.
Old 4th June 2020, 05:31 PM   #3333
djn is offline djn  United States
djn's Avatar
Originally Posted by pragmat View Post
I'm sorry, i just made some sketches and calculations on some sheets of paper, but they are lost by the times.
The waveguide was a leftover from some other tests with 1-Inch dome tweeters. I used it to level up the tweeter and to give it some more direcion and less echo in the room. The crossover seperates it from the speaker at the front at 3000Hz, 12dB, i think.
Both woofer work on the same, pretty big and damped enclosure with a mouth opening of about 40% membransurface. I had to widen up the mouth to place it with the opening to the floor so i checked if that karlsonstyle mouth extension would be a help (or if the ladies had to get a bigger booty).
The woofer in the back comes without crossover to give it a little mor virtual room, that's why i put the holes around it. It passes out at around 6000 Hz.
The upper part is connected with glue to the lower one with a ring of rubber.
@MtBiker
The cavities were a design feature, i attached a foto of the former use with some other speakers.
I really like your style Prag.
Old 22nd June 2020, 05:06 AM   #3334
Dan998 is offline Dan998  United States
Top of the line DIY speakers from about 15 years ago. The speakers use two 7 inch Focal W Cone Midrange drivers, Focal Audiom TD5 Tweeter and two Focal 13 inch W Cone woofers. Top of the line DIY speakers based on Focal drivers. - DanWilson - Speaker Asylum
Old 22nd June 2020, 12:50 PM   #3335
mhouston is offline mhouston  Australia
mhouston's Avatar
Wow if that is your listening room you are a lucky man. I guess the gear just takes it a step further. And why shouldn’t we have orderly, beautiful listening areas where we just want to be. Mine is my lounge and I”M the one who keeps it neat and tidy. Nice environment, nice and just enough gear and bloody good music. That’s me!
Old 30th June 2020, 01:35 AM   #3336
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Compact standmount TL with Purifi PTT6.5 and RS28F in WG300 waveguide and passive Harsch quasi-transient perfect XO.
Simple Passive Harsch XO Using PTT6.5 and RS28F in a Waveguide
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 30th June 2020, 02:18 AM   #3337
workingman1893 is offline workingman1893  United States
what was total cost. i know the Purifi drivers are silly expensive at the moment
Old 30th June 2020, 03:08 AM   #3338
Got Foam?
xrk971's Avatar
Total cost was $1000 for all drivers, XO parts, hardware and wood. I got mine in the GB so saved a little.
Old 30th June 2020, 02:58 PM   #3339
that's actually not terrible. i don't think many commercial speakers can boast what this thing can do
Old 2nd July 2020, 01:44 PM   #3340
Pilover2000 is offline Pilover2000  Canada
Default 3 way active with sub
Current system is Emminence 8 inch bass, 2 6.5 inch phl's open in towers topped by Arum Cantus AST2160 on the front and ATC planars on the back. 15" Legacy driver from PE in the sub.
Alto Stagedrive processor similar to Behringer 2496 using 24 db slopes at 60-380, 380-3000, 3000+. Using Classd Audio SDS470c for 4 channels and tweeters on a little SMSL amp. Sub on Parts Express 1000 watt.
Spotify is usual source with old Musical Fidelity dac set up thorugh USB on the computer. Dirac software on pc to tweak. Old Bedini preamp allows 2 connections, one to main system second to sub as well as allowing volume control.
2-channel sound reproduction is like Alice in Wonderland - Linkwitz
System Pictures & DescriptionHide this!Advertise here!
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
