System Pictures & Description
Old 6th February 2020, 03:33 PM   #3271
djn is offline djn  United States
djn's Avatar
Originally Posted by DorinD View Post
This is the last iteration of my speakers (3-way horn and mono sub-bass, crossovers 100-500-5k). Seems I've got more slam and punch but also gorgeous cello lines compared with the old midbass enclosures (resized Edgar's Show Horns).
Very nice. Say more about those bottom horns.
Old 6th February 2020, 04:05 PM   #3272
DorinD is offline DorinD  Romania
DorinD's Avatar
Before these strait midbass horns I had Bruce Edgar's downsized "Show Horns" and pretty satisfied (not so when playing cello lines). But I used to look after a strait horn to replace them. Not that eager to DIY one of the projects available here or else (not having a proper workshop) my attention was captured by a pair of empty 12inch horn enclosures on US eBay (see the picture). I also found the originals which are made by Audac and named HS212 and got a good deal for a pair from Germany.
Initially I wanted to eviscerate the inside coaxial HF horn but --as it also play phaseplug role-- I let it in place and just used all speaker as it is crossed at 600Hz and 100Hz with the rest of my 3-ways horn system. Now the system is rock solid, I can throw on it anything and doesn't complain at all. All percussion instruments, especially piano which I know how it should sound, are superbly reproduced. It is very liniar till 110Hz where it falls sharply.
It's never too late having a happy childhood
http://www.homebuilthifi.com/project/5604
Old 7th February 2020, 08:18 PM   #3273
djn's Avatar
Thanks D. Very cool looking horn. So it is playing from 100hz to 600hz? I wonder how it would sound with a good compression driver.
Old 7th February 2020, 08:42 PM   #3274
djn's Avatar
Did a little research on these. I think I'm going to look for a pair. With a sub or two they may work well.
File Type: pdf AUDAC-HS212-MK2-Acoustical data (1).pdf (57.1 KB, 18 views)
Old 7th February 2020, 10:53 PM   #3275
DorinD's Avatar
Welcome DJN. Not sure about using it with compression driver as it has large throat for a 12 inch direct radiator in close back chamber. Adding subwoofer you can use it full range --it's coaxial HF horn is taking over from 1.5kHz-- it should not be that bad compared to a synergy which looks cooler.
Old 8th February 2020, 12:50 AM   #3276
djn's Avatar
That horn has a compression driver attached from the factory it says. Didn't say which one so dont know the quality.
Old 8th February 2020, 09:19 AM   #3277
DorinD's Avatar
I didn't take it apart yet, I'll keep you updated as soon as I'd have these inside details.
Old 8th February 2020, 03:00 PM   #3278
djn's Avatar
Great, thanks Dorin.
P.S. I think these look way cooler than the synergy!!!
System Pictures & DescriptionHide this!Advertise here!
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
