System Pictures & Description
System Pictures & Description Please consider donating to help us continue to serve you.
Old 8th December 2019, 07:24 PM   #3231
tonskulus is offline tonskulus  Finland
My latest "just for fun" system for vinyl records. Can't stop listening! So accurate, transparent and wide stereo imaging. Close your eyes and everything you hear is drawn clearly in front of your closed eye vision!
With digital records, 2445J indeed sounds a bit metallic and harsh >7kHz but actually very sweet with vinyl. Much much better than Alpairs alone.
Alpair 10.3 ml-tqwt + JBL 2445J/2380A, crossed at 600Hz. 0.5ms delay.
Minidsp 2x4
Alto 2x31 EQ for horn correction
Bose entero 4400 4-ch amplifier
Onkyo cp-1027, Ortofon 5e cartridge
Old 8th December 2019, 11:36 PM   #3232
nationalkid is offline nationalkid  Japan
Originally Posted by nationalkid View Post
I tried the bass reflex method because there was no bass.
Measured with "DSSF3" and "omnimic".
and Inside.
Old 8th December 2019, 11:57 PM   #3233
Enclosure: Bass reflex,23L
Tweeter: Dyton AMT mini-8,88dB/W
Squawker: Parc Audio DCU-F081PP, 83dB/W,1.3L
Woofer: SB Acoustics SB13PFC-4, 89dB/W
Network: 300Hz, 5kHz cross,12dB/oct
Old 9th December 2019, 09:15 PM   #3234
Since the name of the unit used was wrong, I will correct it.
Enclosure: Bass reflex, 23L
Tweeter Unit: Dyton AMT mini-8, 88dB/W
Squawker Unit: TangBand TBW3881SJF, 88dB/W, 1.3L
Woofer Unit: SB Acoustics SB13PFC-4, 89dB/W
Network Cross Over: 300Hz and 5kHz, 12dB/oct
Old 10th December 2019, 07:13 AM   #3235
Profi is offline Profi  Russian Federation
My new works. 2-Way Beag401 in Onken + Autor FullRange 8"
Old 1st January 2020, 05:14 PM   #3236
pragmat is offline pragmat  Spain
I made this system because my wife and my mother-in-law didn't want to have some fridge-sized speakers in the livingroom and i refuse to buy 2019-sourround-design-speakas.
I made this pair from an old pair of Pioneer speakers with damaged cabinets that i bought on the flea market.
I added a 4 inch woofer i found and made a hornreflexsystem for them with a Karlson-like wide mouth.
Most of my materials i get from the scrapyard like the wooden plates or crossoverstuff from old speakers.
Here i used a sheet of flexible mdf to make the two dancing ladies.
Finally i casted a traktrixhorn-shaped waveguide for the tweeter from plaster.
It is a lot of experimenting and measuring that way, but the sound ist clear and horn-like fast.
So i'm ok with the sound and the ladies like the design.
Happy new year and saludos de Espana
Old 1st January 2020, 11:30 PM   #3237
djn is offline djn  United States
djn's Avatar
Beautiful work!!! Do you have a link to the build?
Old 2nd January 2020, 02:05 PM   #3238
MtBiker is offline MtBiker  United States
Very well executed and I think Gaudi would approve, but is there a reason for the Swiss cheese in the upper cabinet?
Old 2nd January 2020, 03:49 PM   #3239
I'm sorry, i just made some sketches and calculations on some sheets of paper, but they are lost by the times.
The waveguide was a leftover from some other tests with 1-Inch dome tweeters. I used it to level up the tweeter and to give it some more direcion and less echo in the room. The crossover seperates it from the speaker at the front at 3000Hz, 12dB, i think.
Both woofer work on the same, pretty big and damped enclosure with a mouth opening of about 40% membransurface. I had to widen up the mouth to place it with the opening to the floor so i checked if that karlsonstyle mouth extension would be a help (or if the ladies had to get a bigger booty).
The woofer in the back comes without crossover to give it a little mor virtual room, that's why i put the holes around it. It passes out at around 6000 Hz.
The upper part is connected with glue to the lower one with a ring of rubber.
@MtBiker
The cavities were a design feature, i attached a foto of the former use with some other speakers.
Old 2nd January 2020, 11:50 PM   #3240
zman01 is offline zman01  Bangladesh
pragmat,
Nice work, you have a unique set of speakers.
System Pictures & DescriptionHide this!Advertise here!
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
