System Pictures & Description
Old 25th September 2019, 11:39 AM   #3221
batty is offline batty  Australia
Nowhere near finished.
I have gone from 85 watts class AB amplification to an ACA.Gone on to the M2X.
Old 8th October 2019, 08:24 AM   #3222
maik is offline maik  Germany
Default New 4 way active system finished
Here is a 4 way active system I finally finished. The sub contains two peerless sls-8 driver in ported enclosure. Ports are at the back. Filter for the sub kicks in at 100Hz. The upper part is open baffle. For optical reasons the back of the drivers is covered by 10mm basotec in a wooden frame. Frequency range from 80Hz-250Hz is covered by a PHL2460 which is one of the most neutral drivers I ever used. Above 250Hz works a Thiel SCS3 coaxial driver. Tweeter takes over at 2000Hz.
The upper part with the Thiel can be replaced by two other versions. One containing a Manger MSW and a third one with an Eton 5'' and a 25mm Visaton ceramic tweeter. But in fact the Thiel delivers the best trade of between liearity and imaging in my opinion.
Crossover is implemented in a Najda DSP and music is coming from a heavily modified Sony CD player or most of the time streamed from a Raspberry PI 3.
Sub section is powered by two IRS2092 module and the open baffle section by 12 LM3886 (6 modules with 2 LM3886 in parallel each). The Thiel is nominally rated 4 ohms but comes down to 3 ohms partially. Therefor I decided to use LM3886 in parallel. In the future I plan to build 6 CFA amps
for the open baffle section.
Maik
Old 11th October 2019, 11:51 AM   #3223
Pilover2000 is offline Pilover2000  Canada
Very nice !!!
2-channel sound reproduction is like Alice in Wonderland - Linkwitz
Old 23rd October 2019, 12:13 PM   #3224
Tiomo is offline Tiomo
Work in progress, for the next few months (read: years)
File Type: jpg 73417740_519983638550538_5616592556193218560_n.jpg (186.5 KB, 1009 views)
Old 23rd October 2019, 06:17 PM   #3225
kec is online now kec  United States
kec's Avatar
Nice, details please...
Former Altec Employee ('78-'82)
Old 25th October 2019, 03:26 PM   #3226
Bergfinn is offline Bergfinn  Norway
4-way temporary setup.
Fostex T500A
TAD-2001
TAD-1201
GPA-414
Active digital x-over.
Old 14th November 2019, 01:33 AM   #3227
poseidonsvoice is offline poseidonsvoice  United States
poseidonsvoice's Avatar
My GedLee NA12 visited the boutique about a little over 1 year ago. See here for the story:
This GedLee NA12 visited the boutique!
Best,
Anand.
Science is not a democracy - Earl Geddes
DIYAudio is a journey not a destination!
Old 14th November 2019, 03:36 AM   #3228
zman01 is offline zman01  Bangladesh
Best,
Anand.
Nicely done Anand.
Old 23rd November 2019, 03:18 PM   #3229
pragmat is offline pragmat  Spain
Here is my 4-way(3 1/2) garage soundsystem.
There are two JBL 2234 , two 2225, two 2445 and two 2405 Al
Upper woofer start at 60 Hz and all 4 go up to 650 Hz, where the horn comes in.The 2445 gos up to 10000 Hz.
Horn and most of the lower speaker cabinet ist made of stoneplates , concrete and concretefiber. The other used material is mostly multiply with a matrix-like inner stabilisation.They are vented as recommended by JBL
The 2234 is powered with a Vincent 231, the rest with a Rotel 976. There are 2 Behringer 2496 working as crossovers , one for each side.
Food comes direct over the digital entrance of the DCXs or analog with a Denon PRA 1100 for recordplayer or FM radio.
In the near future i will change the Rotel to some class D amps and play around with other amplification to compare to the Vincent powerpack.
At the moment i comb my hair with the new Tool album.
Greetings from Spain
Old 4th December 2019, 07:43 PM   #3230
Rewind is offline Rewind  Sweden
Rewind's Avatar
I do something similar, but I cross the mid-range horn from 440-2000Hz. From there, a Raal ribbon in a horn from 2000Hz to 20k.
System Pictures & DescriptionHide this!Advertise here!
Copyright ©1999-2019 diyAudio
