System Pictures & Description
Old 8th August 2019, 08:45 PM   #3201
carpenter is offline carpenter  United States
Paper mache horn fabricator
carpenter's Avatar
Here a three way horn system I'm fabricating. The larger horn is a bass/mid bass unit (50hz to 250hz), the smaller horn in the upper left is the midrange unit (250hz to 6000hz) and the tweeter horn is a sweet sounding Fostex.
The midrange horn is paper mache. The bass/midbass horn is solid maple. The drivers are Ale.
I enjoy audio so much that I constructed a web site. I share my ideas at: www.inlowsound.com
Old 8th August 2019, 09:02 PM   #3202
Rewind is offline Rewind  Sweden
Rewind's Avatar
Amazing work. But the horn mouths, shouldn't they be bigger? I use a hoen from 440-2000Hz and the mouth is about 80x50cm. Any measurements?
Old 8th August 2019, 09:48 PM   #3203
carpenter's Avatar
Here's an RTA of the bass horn. I don't have one of the midrange, yet.
Old 8th August 2019, 09:49 PM   #3204
carpenter's Avatar
This was taken using pink noise, with only the floor boundary. There were no side walls.
Old 29th August 2019, 05:42 AM   #3205
tonskulus is offline tonskulus  Finland
Simple pair (prototypes) of my own ml-tqwt designs. Same drivers used as my previous "table top" reflexes: Vifa bc25sc55 and modified TB w4-992s.
Neutral is the word for these. Easy to listen for a long perioids, bass extends down to 40Hz easily and there is good amount of it.
Old 11th September 2019, 08:16 PM   #3206
spswmsw is offline spswmsw  Ukraine
spswmsw's Avatar
Celestion K12H-200TC (on a full range) + Fountek NeoCD3.5H (above 10 kHz)
Bass reflex, сabinets 190L.
Old 11th September 2019, 08:50 PM   #3207
domtw is offline domtw  France
domtw's Avatar
Amazing construction!
How did you fabricate that?
Do you have some pictures of the process?
Finished speakers: ArkBlack - RedArk - SD-miniArk
Old 14th September 2019, 08:04 PM   #3208
falpi is offline falpi  France
2 ways / full horn.
It's still under construction for acoustics and finishes.
YouTube
Old 15th September 2019, 08:44 AM   #3209
kazap is offline kazap
kazap's Avatar
Originally Posted by falpi View Post
2 ways / full horn.....
Nice work. The floor concrete bass horns with Altec 515 sound great. How low do they go?
Old 15th September 2019, 08:47 AM   #3210
mhouston is offline mhouston  Australia
mhouston's Avatar
Looks like a lot of work. Well done.
System Pictures & DescriptionHide this!Advertise here!
Copyright ©1999-2019 diyAudio
