System Pictures & Description
Old 7th July 2019, 07:44 PM   #3191
8x24 inch is offline 8x24 inch  Norway
GD measured in the listening position
Old 8th July 2019, 01:25 AM   #3192
slogan2112 is offline slogan2112  United States
Default SSA-WG speaker project
I completed my speakers that I have been working on for quite some time.
A few details;
Name:
The SSA-WG is a 3-way Scan-Speak Accuton WaveGuide project.
Drivers:
Woofers: 2x Scan-Speak 22w/8857T00 (parallel)
Midrange: Accuton C173-6-090
Tweeter: Scan-Speak D3004/6640 mounted to a Jantzen Waveguide
Crossover:
Duelund with approximate crossover frequencies of 300Hz and 2150Hz
Details can be found linked below
Introducing the SSA-WG
It was quite the journey. It was my first design from scratch. I used Soundeasy for crossover design. Learned woodworking skills along the way.
They sound very good.
Here's a few pics.
System Pictures & Description-dsc_0021_500k-jpg
System Pictures & Description-img_3483_500k-jpg
System Pictures & Description-dsc_0451_500k-jpg
System Pictures & Description-dsc_0454_500k-jpg
System Pictures & Description-dsc_0459_500k-jpg
System Pictures & Description-dsc_0457_500k-jpg
Old 8th July 2019, 01:55 AM   #3193
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Very nice job with the bamboo ply. What grade did you use?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 8th July 2019, 02:38 PM   #3194
Thanks Dave, I don’t think bamboo has a grade like Baltic birch...I could be wrong. I used 1” thick cross laminated vertical grain carbonized bamboo ply. There were some small voids on the edges I filled with epoxy. Hearing from others it’s kind of hit or miss on the consistency.
Scott
Old 8th July 2019, 05:12 PM   #3195
frugal-phile(tm)
planet10's Avatar
It does, it comes in horizonatl, vertical, and stranded varietes. I do not recommend the horizontal, probably not as good (but not as pretty) as good BB. Vertical is what i find most used, stranded thou is better by a long margin, and has a much tougher surface as far as collecting dings goes.
dave
Old 8th July 2019, 10:08 PM   #3196
I used the vertical type and that's also what I have seen most used. It's very hard, you need good sharp tools. Really no dings during the build. Here's a few pictures. The top is stacked end pieces to highlight the bamboo ends. I find it an excellent material for speaker building.
System Pictures & Description-dsc_0271_200k-jpg
System Pictures & Description-dsc_0270_200k-jpg
Old 8th July 2019, 10:20 PM   #3197
frugal-phile(tm)
planet10's Avatar
Thanx,
We have used both vertical & stranded, the stranded is something else. The vertical is still very good.
dave
Old 8th July 2019, 10:35 PM   #3198
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
Wow, that's some very fine looking joinery.
jeff
Old 10th July 2019, 05:02 AM   #3199
JRSystems is offline JRSystems  United States
Outstanding cabinet work!
System Pictures & DescriptionHide this!Advertise here!
Copyright ©1999-2019 diyAudio
