System Pictures & Description
Old 4th March 2015, 01:17 AM   #2701
thetubeguy1954 is offline thetubeguy1954  United States
thetubeguy1954's Avatar
Send a message via Yahoo to thetubeguy1954
Wow MiWi!!!
I didn't realize how darn big those horns were! DIY huh? I'm thoroughly impressed. I have a great audio ear, but not even a smidget of DIY capability when it comes to building amps, preamps, or horns such as yours. I wished I lived near you as I'd love to hear a system such as yours!
Congratulations on building such a wonderful looking (and I'm sure wonderful sounding as well) audio system and speakers! You're a very talented person.
Thetubeguy1954 (Tom Scata)
Central Florida Audio Society--SETriodes Group--Space Coast Audio Society--Full-range/Wide-range Drivers--High Sensitivity Speakers--Front & Back-Loaded Horns.
Old 4th March 2015, 05:17 AM   #2702
MiWi is offline MiWi  Germany
Thank you.
Yes, I already thought about some subbasshorns instead of the tapped horns.
(I already did the simulations and made the CAD drawings)
My wife has not been amused.
Im quite pleased with the tappedhorns, so this is not an urgent project.
Old 4th March 2015, 07:05 AM   #2703
The speakers indeed look quite small with the pictures of the whole room.
I guess this is because the ceiling is quite high. (sloping from 8ft to 17ft high)
The midbasshorns are nearly 4ft wide, 3ft high and more than 4ft deep.
The midhorns are 28" wide and 22"high (hornmouth).
Their size is one reason why I hesitate with the subbasshorns
I really love the look of spiral horns (like John built them for example).
And they would fit really nice under the sloping ceiling, making for a giant hornmouth-extention.
But Im not sure if the looks will be to much with 2 spiralhorns.
The midbass/midhorns are quite prominent with their kind of "space-age" look and their size.
As the tappedhorns hide quite well and are nearly invisble, the focus is on the main speakers, which keeps a good balance I think.
Right tappedhorn, hidden in the other room and just "firing" into the living-room.
Left tappedhorn, pretending to be some kind of bench.
Old 4th March 2015, 07:18 AM   #2704
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
What are the other dimensions of the room... i ask because my ceiling goes from 7->17'. The sloped ceiling really helps room sonics.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 4th March 2015, 07:33 AM   #2705
Living room and kitchen-area are one space (can be seen on the last picture on the right side).
The whole room is about 32ft wide (about 22 where the speakers are) and 26ft deep.
All the walls are drywall (1" wood + 1/2" gypsum cardboard), which means the whole room is a panel bass absorber.
I got really little problems with bass-peaks, the reverberation time underneath 300Hz is really good. The hole for the stairs also helps with this.
I designed the house (and built most part of it).
First of all it is a livingroom and I wanted it to look good / feel good. I just tried to get a good compromise for the music as well and aimed for a roomgeometry which will give little problems with bass.
Mid high reverberation could be improved.
But it is by not as bad as most people would think from the pictures. The speakers are beaming strong and the walls are quite far away.
There are acustic absorber hidden behind the pictures, but Im planning to get more.
I placed an order for two big new pictures printed on acustic-cloth (each 4ft x 6ft), which I will wrap around 4" thick absorbers. They will be placed on the right side where the white picture is now.
The curtain on the window on the left will be replaced with slideable acoustic panels. (4 panels 2ft x 5ft)
(symmetry left/right is important, tested some different arrangements to find out about the influence)
The speakers are are not aligned parallel to the back wall intentionally. They are angled to get nearly the same delay for the first reflections on the listening spot.
Old 4th March 2015, 07:35 AM   #2706
frugal-phile(tm)
planet10's Avatar
The whole room is about 32ft wide (abouit 22 where the speakers are) and 26ft deep.
Similar size to mine which is 24 x 36' with everything open (except the bath)
dave
Old 4th March 2015, 07:43 AM   #2707
Id bet you dont have big problems with room modes and room gain, too.
Old 5th March 2015, 05:58 AM   #2708
TerryO is offline TerryO  United States
TerryO's Avatar
Actually, Dave's room sounds very nice and I've spent many hours (over a number of years) listening to different speakers and gear.
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 30th March 2015, 05:18 AM   #2709
stewin is offline stewin  Kenya
very lovely cool work
Old 2nd April 2015, 03:22 PM   #2710
LandIsland is offline LandIsland  Norway
LandIsland's Avatar
System Pictures & DescriptionHide this!Advertise here!
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
