The cap seems to be leaking any recommendations on what caps to use as will replace them all?
M mafia1976 Member Joined 2012 2013-04-01 11:58 am #21 2013-04-01 11:58 am #21 The cap seems to be leaking any recommendations on what caps to use as will replace them all? Attachments P1000455.jpg 992.7 KB · Views: 77 ••• More options Share M mafia1976 Member Joined 2012 2013-04-01 12:27 pm #22 2013-04-01 12:27 pm #22 Also would the 8" from an AR6-7 be ok to use for the lower mid as it's XO point is 200-1200hz? this is within the spec for this speaker? i really want to get rid of the non original LMR that has been fitted.. Thanks in advance Matt. ••• More options Share Prev 1 2 First Prev 2 of 2 Go to page Go Show hidden low quality content Status This old topic is closed. If you want to reopen this topic, contact a moderator using the "Report Post" button.
