Wharfedale W60 Tweeters
Old 29th January 2013, 03:47 AM   #1
compaxa12 is offline compaxa12  United States
Default Wharfedale W60 Tweeters
Looking for someone or somewhere to rebuild a wharfedale W60 8 ohm tweeter. Or, someone that has one for sale. The voice coil is smoked. It reads 6.4 ohms DC Resistance but you can see the coil all messed up and nothing but a little screaching sound when connected to an amp. Thank you. Compaxa12.
Old 2nd February 2013, 07:20 AM   #2
devilsindetails is offline devilsindetails  Canada
devilsindetails's Avatar
Pics are essential so that we know which version of the W60 you are talking about and the type of tweeter.
Better off IMO to source replacement tweeters for both enclosures as most ( but not all) Wharfedale tweeters were underwhelming, to say the least...repair of your tweeter, while not impossible, is probably not your best course of action
"A problem left to itself dries up or goes rotten. But fertilize a problem with a solution--you'll hatch out dozens." (N.F.Simpson)
Old 10th April 2013, 01:55 AM   #3
Rockaway is offline Rockaway  United States
Rockaway's Avatar
I am in the same boat. Burned Voice coil. I have the w70 alnicos with a paper dust cap. gold paint no back sticker. edges were foam not felt and there was no spider that I can find. only a small foam dampener behind the dust cap. I am going to take a shot at a home brew re-edge. The voice coil is another matter. No suppliers or ma and pop speaker shops will touch the job. I am thinking of using a coil from another (read cheaper) Super3 model such as the ceramic models which are more plentiful and may have same guts. Any thoughts?
Old 10th April 2013, 02:47 AM   #4
VaNarn is offline VaNarn  Australia
The tweeter that is described by Rockaway appears to be the earlier version of the Super 3 that used a straight sided paper cone and a flat foam plastic surround.The voice coil wire is aluminium.The later ceramic magnet version is an improvement (cough!) of sorts but uses a different frame and may not readily fit into the original cut out of the enclosure.Pictures would help,but there is a case for a modern replacement that can be crossed over at around 1 kHz.
Old 10th April 2013, 02:51 AM   #5
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
There are lot's of us with shelves full of dusty tweeters that we don't necessarily know where they came from. Who knows, there might be an old pair just sitting there. Pics are very helpful, front and back.
Old 10th April 2013, 03:50 AM   #6
Rockaway's Avatar
Hope these work. Had to find password info for image shack....
http://imageshack.us/a/img29/2928/imageurrv.jpg
http://imageshack.us/a/img22/6328/imageghg.jpg
http://imageshack.us/a/img819/2240/imagevfh.jpg
Old 10th April 2013, 03:52 AM   #7
Rockaway's Avatar
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
Old 10th April 2013, 03:53 AM   #8
Rockaway's Avatar
Old 10th April 2013, 03:53 AM   #9
Rockaway's Avatar
That's better. Sorry for the first set. Been a while since I used this site.
Old 10th April 2013, 04:00 AM   #10
Speakerholic
Cal Weldon's Avatar
Nope, none of those here, sorry.
Wharfedale W60 TweetersHide this!Advertise here!
wharfedale dovedale cone head Multi-Way 13 7th July 2014 10:46 AM
Hi what you think about wharfedale vr300? frompie Full Range 0 5th March 2012 03:46 PM
FS - Focal TC90K Tweeters MATCHED PAIR Tweeters Mint Condition Unused. Julss Swap Meet 1 20th May 2010 04:45 PM
Wharfedale dobias Multi-Way 0 16th November 2007 04:35 PM
Wharfedale 9.2 enter Multi-Way 4 14th January 2006 02:24 PM
Copyright ©1999-2019 diyAudio
