rePhase, a loudspeaker phase linearization, EQ and FIR filtering tool
Old 10th July 2020, 12:40 PM   #3031
4real is online now 4real  Netherlands
I'm trying to get RePhase to run on a Mac using Crossover. Sadly it does not want to start yet. It gives me exit code 9, which sounds quite specific. I count not find any documentation on this. Anyone an idea what it indicates?
Do diamonds shine on the dark side of the moon?
Old 10th July 2020, 02:46 PM   #3032
Well, I got it working using Docker, but it really a huge pain in the a$$.
Old 14th July 2020, 01:18 PM   #3033
Tenson is offline Tenson  United Kingdom
I'm trying to use Re-Phase to build a linear phase 2 way speaker. First time I've used it.
It seems to be working well, except that when I confirm the response with the linear phase high-pass it bottoms out at about -30dB.
Any tips on what is happening here? Re-phase simulation doesn't look like that.
I tried 2000 and 8000 taps. Same result. If I use minimum phase high pass it doesn't do this.
Old 14th July 2020, 04:44 PM   #3034
P.S. I'm running he filter in an Analog Devices ADAU1452 and Sigma Studio.
Old 14th July 2020, 08:46 PM   #3035
pos is offline pos  Europe
pos's Avatar
Are you using the same convolution engine and number of taps for the linear-phase and minimum-phase versions?
waveTracing | rePhase
Old 14th July 2020, 09:27 PM   #3036
Exactly the same setup, just changed the coefficients table in the DSP. The minimum phase version was 2000 taps. I tried linear phase with 2000 and 8000 taps.
Should I generate separate coefficient tables for the minimum phase components of the correction such as parametric EQ and another for the linear phase crossover filter?
It looks to me as though whatever type of filter is used in Re-Phase it is actually exporting an FIR filter? I mean minimum-phase filters in Re-Phase are actually FIR approximations of minimum-phase filters, is that right? I thought 'true' minimum-phase filters have a fixed number of coefficiants depending on the filter order, don't they?
I hope my question makes sense. In Sigma Studio I can choose either an FIR or IIR filter block and then load the coefficients. I was using the FIR filter block for both of these examples since they both looked like FIR filters with 2000 coefficients.
Old 15th July 2020, 12:51 AM   #3037
It seems to be working better all of a sudden... I'm not sure why. If I find out I'll report back!
Old 15th July 2020, 07:39 AM   #3038
pos's Avatar
My guess is that ARTA is not considering the whole impulse when calculating the frequency response, and is cropping too much signal before the impulse peak, expecting a minimum-phase behavior.
Here is an example with HOLM, lower part showing the windows used:
rePhase, a loudspeaker phase linearization, EQ and FIR filtering tool-2-png
See if you can change the measurement window in ARTA.
There is no need to do that.
rePhase is only generating FIRs indeed, suitable for a convolution engine.
There is no such thing as IIR in real life after all: you can only measuring a FIR
Old 15th July 2020, 03:17 PM   #3039
Bingo! You are correct!
It was user error, not ARTA at fault. I had kept the gate in the same place as my raw measurement, but it was too close to the start of the impulse as you said. Never seen low frequencies at the start of an impulse before, haha!
Thanks for your lovely software!
Old 29th July 2020, 02:36 AM   #3040
charlesp210 is offline charlesp210  United States
charlesp210's Avatar
Default RePhase working on Mac
I just used rePhase 1.3.0 on my 2012 Mac mini running Mac OS 10.13.6 using Wine 3-18. I generated some linear phase LR8 crossover filters, something I'd planned to do for 33 years, finally got around to it today.
It generates a few pages of error messages on startup in the Wine shell window, but seems to run OK, mostly, I wouldn't keep it running for days because I've had some weird things happen recently, but maybe nothing to do with Wine and rePhase.
I am so happy to use this fine and very flexible program, and on my Mac too.
rePhase, a loudspeaker phase linearization, EQ and FIR filtering toolHide this!Advertise here!
FIR linear phase plugin for MiniDSP? diyjb01 miniDSP 17 9th June 2016 01:35 PM
FIR filter design tool for Loudspeaker magnitude equalization ttmusic Software Tools 3 24th May 2013 08:30 PM
FIR Filtering experiences Olombo PC Based 8 10th February 2013 03:45 PM
AVX based FIR VST, crossover / EQ / DRC and delay KOON3876 PC Based 97 26th November 2012 07:18 AM
Phase EQ using FIR filters Grasso Multi-Way 2 2nd July 2003 10:37 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
