rePhase, a loudspeaker phase linearization, EQ and FIR filtering tool
rePhase, a loudspeaker phase linearization, EQ and FIR filtering tool Please consider donating to help us continue to serve you.
Old 28th October 2019, 09:22 PM   #2811
pos is offline pos  Europe
pos's Avatar
Hello serko70
I cannot help you on the Roon integration part, but the REW measurement import part is extensively covered in several tutorials, links to many of which you will find on the rephase.org page.
2019-01-16: rePhase 1.4.3
Old 7th November 2019, 12:22 AM   #2812
falvespinto is offline falvespinto  Portugal
I am rather new to Rephase and REW and have been trying to linearise my passive speakers. I am using vs 1.4.3 of Rephase and 5,19 of REW. I have read some tutorials but cannot export the automated EQ from REW to Rephase as .txt files, it isnīt generated in the expected format. What can I do apart from copying all the settings by hannd and inserting them on the paragraphic eq ?
As an aside, and probably the wrong place to ask, but as I try to time-align in REW all the measurements without windowing using the " estimate IR delay" and then accepting the shift , I see that not only some donīt land on the first big step response peak / zero ref. time, the ones that donīt are at diferent, and sometimes largish time distances from the relevant peak...Then if I manually shift them to properly line 0 ref time precisely with the peak often the zero, dotted red line doesnīt line with zero time and the peaks curve sort of "wiggle" and slightly change shape as I try to precisely get the zero on top of the peak...Is this normal, am I doing the alignement right or should I leave it at where the estimated time shift lands?
Thanks, newbie posting here, if infringing normal forum behaviour, let me know, and thanks in advance for any input.
Old 8th November 2019, 05:34 PM   #2813
PMental is offline PMental  Sweden
To get the correct (XML) format for the export make sure you use the "Save filters to file" option in the EQ window under "Filter Tasks".
Old 9th November 2019, 12:49 AM   #2814
Right, thanks PMental.
Anyway, I am afraid to get the phase all screwed up on REW with the impulse response delay estimation and the problems described, it doesn't even seem to settle in the same peaks, sometimes tbe first, others on the second, so I am not sure I am getting proper summation of responses when I vector averge them before applying smoothing and equing the result to export to Rephase..
Old 9th November 2019, 01:04 AM   #2815
thierry38 is offline thierry38  France
Is it you Thomas ?
Old 9th November 2019, 03:35 AM   #2816
fluid is offline fluid  Australia
If you can take a screenshot of the differences in impulse timing it will be easier to help.
The time align function will usually get them within one sample delay, it is possible to get them closer but the difference only shows above 10Khz due to the wavelengths being so short. This shows the difference blue is REW alignment red is manual. 5dB per grey line. Not really anything to worry about.
rePhase, a loudspeaker phase linearization, EQ and FIR filtering tool-screen-shot-2019-11-09-11-58-31-am-png
File Type: png Screen Shot 2019-11-09 at 11.58.31 am.png (114.9 KB, 387 views)
Old 10th November 2019, 06:46 AM   #2817
emailtim is offline emailtim  United States
Question about @SwissBear's Tutorial PDF. In the last step, it appears there are 3 files for each channel.
1) Averaged measurement file exported from REW (as .txt).
2) AutoEQ file exported from REW (as .xml).
3) Excess Phase file exported from REW (as .txt).
As I read it, it then instructs importing all 3 of these files into rePhase to generate the final convolver file (Averaged Measurement, AutoEQ into "Parametric Gain EQ" and Excess Phase into minimum phase corrections).
How can you load the Excess Phase (.txt) file into rePhase's minimum phase corrections? I only see a way to load the REW AutoEQ and averaged measurement file.
There is an "import REW filter settings (.xml)" pulldown menu option under "Parametric Gain EQ", but I don't see an equivalent for the excess phase import.
I might be missing something.
TIA
Using:
  • rePhase 1.4.3
  • REW V5.20 Beta 27
Old 10th November 2019, 09:35 AM   #2818
TIA
The excess phase measurement should be loaded separately, then by using the paragraphic phase EQ and filters linearization the idea is to make the measurement closer to a flat line to remove the excess phase and leave you with an approximate minimum phase result.
The workflow to follow the tutorial should be:
1) Create vector averaged measurement
2) Use FDW and smoothing to avoid overcorrecting later
3) Use REW auto EQ or manual to correct the windowed response to your target
4) Save the filters to file and export the averaged measurement as text
5) Open the measurement in Rephase and import the REW filters from file
6) Generate the correction filter
7) Apply that filter in REW by using A*B function in All SPL tab then reduce level back to original
8) Generate excess phase version in REW
9) Export excess phase measurement as text, import to rephase
10) Correct excess phase back to flat or as much phase EQ as you are willing to use
11) Generate an overall filter in rephase by combining the REW and phase correction
Make more sense?
Old 10th November 2019, 05:10 PM   #2819
Make more sense?
Thanks Fluid.
I thought the EXCESS PHASE file was the correction (analogous to the AutoEQ file), not a template guide for manual correction.
The PDF in step 4 indicates loading the averaged file again which threw me off.
"4) ... Once you have finalized the phase correction, you can import the initial averaged measurement in rePhase and apply the REW filters. ..."
Old 11th November 2019, 03:58 AM   #2820
Oabeieo is offline Oabeieo  United States
Default Question on linearization
So I have a question on linearization
I have a sub that has a LR4@80hz
My sub is QTC.83 and a f3 of 45hz (sealed obviously)
(18” sundown SA-18)
The box linearization looks a lot like the filter linearization, they are very close as far as shape in rephase
Can I just do the box linearization and get the filter linearization simultaneously with one go at it OR do I need to do both linearizations
I listen to both and both sound good.
What is proper in this scenario? As one is a box linearization and one is a filter , does that change anything or do they both need to be accounted for separately,
Thanks in advance:-)
rePhase, a loudspeaker phase linearization, EQ and FIR filtering toolHide this!Advertise here!
FIR linear phase plugin for MiniDSP? diyjb01 miniDSP 17 9th June 2016 02:35 PM
FIR filter design tool for Loudspeaker magnitude equalization ttmusic Software Tools 3 24th May 2013 09:30 PM
FIR Filtering experiences Olombo PC Based 8 10th February 2013 04:45 PM
AVX based FIR VST, crossover / EQ / DRC and delay KOON3876 PC Based 97 26th November 2012 08:18 AM
Phase EQ using FIR filters Grasso Multi-Way 2 2nd July 2003 11:37 PM
Copyright ©1999-2019 diyAudio
