rePhase, a loudspeaker phase linearization, EQ and FIR filtering tool
Old 10th August 2019, 05:56 PM   #2741
Oabeieo is offline Oabeieo  United States
Originally Posted by torgeirs View Post
This is very interesting:-)
Can you draw a picture of this setup with responces and corrections?
signal - rew - amp - 2"
- rew - amp - 8"
As I understand it the 2" is cancelling the reflections at about 800Hz?
Maybe in an own thread. I know it is a lot of work, but the solution is fantastic!
Yeah Iíll do a separate thread in the car audio section
And not clutter this fine thread.
When I get stumped this thread has the the right ppl to help me get on track
Itís not a cure all , but definitely takes the edge off. It works surprisingly good, but also has its own little issues that are a way better trade off
I reduced the power going to the 2Ē and that seems to work the best. I also added some very aggressive compression as well. But basically just took the difference of the 8 in and out of the pod. Averaged the two and inverted it.
I also built linear phase crossovers for the 2Ē and band limited them to 600-1k
48db slopes. I only wanted to target the modal midrange where I was having issues and the 2Ē was worthless under 600 and seemed to cause more issues that Iím not smart enough to deal with. The 2Ē just barely barely playing stops the issue, the more power I put on it the more the other issues came up.
So itís in a happy place now (I think) ;-)
Thatís where I stared as the response to the 2Ē and that alone worked pretty good , Iím sure it could be better but for a guess it did what I wanted so hey....canít argue with results.
Old 11th August 2019, 02:28 PM   #2742
torgeirs is offline torgeirs  Norway
Super!
600Hz to 1k is 34cm to 57 cm wavelength so 2" is not directive in that erea.
So maybe that explains why it is working so well.
And of cource you need the very good phase control that REW provides.
A comparition is noice cancelling headphones, and we all know they work! (With some ekstra work put into it because the canselling is done with the same speakercone as the signal:-))
Old 13th August 2019, 09:23 AM   #2743
mpa is offline mpa  United Kingdom
A question for the Rephase experts! Can anyone explain why I get exactly half the latency in Rephase than I do in fir Designer for the exact same number of taps at the same sample rate??
Old 13th August 2019, 11:29 AM   #2744
mark100 is offline mark100  United States
Check where impulse centering is...
Old 14th August 2019, 09:23 AM   #2745
Thanks for the tip! Even with the exact same centering as fir Designer Rephase
still shows slightly less latency though.
Old 14th August 2019, 12:31 PM   #2746
Glad it helped !
How much less latency?
Are you letting both programs determine centering?
Oh, and did you use Find Peak in FirD?
rePhase, a loudspeaker phase linearization, EQ and FIR filtering toolHide this!Advertise here!
FIR linear phase plugin for MiniDSP? diyjb01 miniDSP 17 9th June 2016 01:35 PM
FIR filter design tool for Loudspeaker magnitude equalization ttmusic Software Tools 3 24th May 2013 08:30 PM
FIR Filtering experiences Olombo PC Based 8 10th February 2013 03:45 PM
AVX based FIR VST, crossover / EQ / DRC and delay KOON3876 PC Based 97 26th November 2012 07:18 AM
Phase EQ using FIR filters Grasso Multi-Way 2 2nd July 2003 10:37 PM
Copyright ©1999-2019 diyAudio
