Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Multi-Way Conventional loudspeakers with crossovers |
#2661 | |
I'm using Equalizer APO. It uses FFTW3 for convolution. I doubt that's the case since the convolution causes no distortion if there are only high- or low-pass filters. The first chart included a 3-way crossover generated with rephase yet the distortion level was lower. I'm attaching a screenshot with EQ settings for the tweeter. Amplifier's volume setting was the same. Actual volume was lower due to the equalization applied. I'm attaching a volume comparison chart as well. |
#2662 |
You might just be seeing an increase in relative noise ratio then.
2019-01-16: rePhase 1.4.3 |
#2663 |
It's a good idea to include the noise floor when looking at distortion plots, and to check the plot without normalisation.
#2664 |
#2665 |
pos, when do you plan to release the bugs implemented last week on high altitude in the alps?
#2666 |
A question (for fun/learning).
What about the : Dolph–Chebyshev window (rePhase or REW) ? Any trade-off ? ![]() Last edited by thierry38; 12th March 2019 at 07:34 PM. |
#2667 |
About the distortion measurements of chebum, they were the farfield measurement of loudspeaker's output. We saw only distortion curves with percentage, not dB.
Typical domestic ambient noise level is 30-35dB. Typical hifi-loudspeaker must play at 95dB/1m or louder to show "real" distortion above noise level. One standard is to measure/set spl to 95dB at 1000Hz with some smoothing of response. Another way is to use standard voltage, but then we must also see the measured dB values to compare. In theory, loudspeaker equalization always leads to higher distortion levels (when we look at spectrum). There is no way to raise efficiency or lower distortion by eq. When input voltage is lowered, distortion gets lower too. With eq we typically suppress loud parts of spectrum which leads to effectively lower total efficiency. Then, to get same spl level in a measurement (say that 95dB/1m), we must use higher voltage and we will see higher distortion percentage. If quiet parts of response are amplified, distortion rises just as well and for same standard spl, we get higher distortion again. The problem with this is that we might introduce clipping in loud parts of music signal, in digital domain. It is very common to see music playing very close to clipping of even badly clipping because of "the loudness war" in original signal, so there is not room for eq left. The propability of this depends on where in signal chain spl volume control and eq is performed. Last edited by Juhazi; 12th March 2019 at 08:25 PM. |
#2668 | |
#2669 | |
#2670 |
Hello,
I noticed something when tested my DE250 on RCF H100 horn. Did a FIR and then an IIR high pass @ 1200Hz. The phase for the IIR filter is corrected with some 'compensate' 2nd order all-pass. So the measurement looks the same but I can clearly say that the sound is more detailed/refined with the IIR filter. It has a better definition, 'bite'. I listen at low level, 70 to 85dB at listening position. What is the cause? the pre-ringing of the FIR filter? Thanks! |
Thread | Thread Starter | Forum | Replies | Last Post |
FIR linear phase plugin for MiniDSP? | diyjb01 | miniDSP | 17 | 9th June 2016 02:35 PM |
FIR filter design tool for Loudspeaker magnitude equalization | ttmusic | Software Tools | 3 | 24th May 2013 09:30 PM |
FIR Filtering experiences | Olombo | PC Based | 8 | 10th February 2013 04:45 PM |
AVX based FIR VST, crossover / EQ / DRC and delay | KOON3876 | PC Based | 97 | 26th November 2012 08:18 AM |
Phase EQ using FIR filters | Grasso | Multi-Way | 2 | 2nd July 2003 11:37 PM |
New To Site? | Need Help? |
