rePhase, a loudspeaker phase linearization, EQ and FIR filtering tool
Old 2nd January 2019, 07:17 PM   #2621
mark100 is offline mark100  United States
Hey POS,
Could a FIR file be built that has coefficients built to regular impulse centering,
and also have coefficients that apply only to certain frequencies at a time later than the frequencies initially went thru?
I bet that made no sense at all...LoL..
Here's the example/goal....
Say a CD driver/horn has a 2000Hz reflection head back into the horn throat caused from discontinuity in the horn mouth.
That reflection back to the throat then rebounds back out the horn in delayed fashion ( vs the ongoing signal).
Is there a way that the 2000Hz reflection could be be nulled with a small out of polarity 2000Hz 'injection' at the appropriate time?
Old 3rd January 2019, 09:12 PM   #2622
pos is offline pos  Europe
pos's Avatar
Originally Posted by TNT View Post
The "FFT-length" - how does it impact the generated filter? Is there a limit in the target HW (e.g. DAM DAC) to be considered?
Originally Posted by thierry38 View Post
FFT lenght defines resolution at low frequency.(and ripple treshold)
Depends of sampling frequency.
More lenght,(taps) more resolution in the lows.(steepness slope and high Q).
Same as windowing impulse with REW,Holm,Arta...
The "FFT length" parameter in rephase is only used for internal calculations and mainly impacts result visualization apparent resolution, and iterative optimization behavior (to a point). What matters most is the number of taps, and this is what Thierry describes.
You can leave FFT length at its default setting and not worry about it.
I should probably just hide this parameter in future versions...
2019-01-16: rePhase 1.4.3
Old 3rd January 2019, 09:16 PM   #2623
TNT is offline TNT  Sweden
OK so if I generated two filters where the only difference was the "FFT-length", both files would be identical?
More distortion to the people!
Old 3rd January 2019, 09:26 PM   #2624
pos's Avatar
Originally Posted by mark100 View Post
Hey POS,
Hi Mark
Never tried this myself, but from the top of my head that should/could be doable by mixing (with sox, audacity, etc.) the initial FIR with a second one generated from identical settings but with an added delay, inverted polarity, and EQ/gain to mimic what really goes back to (and off!) the throat...
Good luck measuring and identifying the proper parameters though
Old 3rd January 2019, 09:27 PM   #2625
pos's Avatar
If you are not using iterative optimization, yes, even if the result curves do not look the same down low.
Old 3rd January 2019, 09:56 PM   #2626
3ll3d00d is offline 3ll3d00d  United Kingdom
3ll3d00d's Avatar
This sounds the same as the virtual bass array approach that I have seen (and have implemented myself) using acourate, details in Virtual Bass Array | Digital Room Correction
I would be slightly surprised if this is feasible/useful at 2kHz though
Old 3rd January 2019, 10:22 PM   #2627
Originally Posted by pos View Post
Hi Mark
Good luck needed !! Lol
But hey, this paper just linked by brinkman in another thread gives me hope http://mariobon.com/Articoli_storici...s_ETF2010d.pdf
Thanks POS
@3ll3d00d....cool, must study your post
Old 3rd January 2019, 11:03 PM   #2628
pos's Avatar
Very interesting! Is this your website and system?
That makes me want to experiment with all this!
One more feature on the todo list for rephase 1.5.0 I guess
Old 3rd January 2019, 11:10 PM   #2629
pos's Avatar
You can think of addressing what is reflected from the mouth back to the throat and remitted from there, but you cannot address what is directly diffracted /emitted from the mouth (or any discontinuity in the profile for that matter) to the listener, because this will change from one position to another.
Unfortunately the latter is probably more audible than the former.
Old 4th January 2019, 06:35 AM   #2630
3ll3d00d's Avatar
sorry, didn't mean to give the impression that is my website, I just meant I have previously used that approach in my system (and that site is the one I remember that documented it).
rePhase, a loudspeaker phase linearization, EQ and FIR filtering toolHide this!Advertise here!
FIR linear phase plugin for MiniDSP? diyjb01 miniDSP 17 9th June 2016 01:35 PM
FIR filter design tool for Loudspeaker magnitude equalization ttmusic Software Tools 3 24th May 2013 08:30 PM
FIR Filtering experiences Olombo PC Based 8 10th February 2013 03:45 PM
AVX based FIR VST, crossover / EQ / DRC and delay KOON3876 PC Based 97 26th November 2012 07:18 AM
Phase EQ using FIR filters Grasso Multi-Way 2 2nd July 2003 10:37 PM
Copyright ©1999-2019 diyAudio
