rePhase, a loudspeaker phase linearization, EQ and FIR filtering tool
Old 7th November 2018, 11:59 PM   #2571
mark100 is offline mark100  United States
Sorry you're having to go through the hassle, Pos.
And many continued thx !
Old 8th November 2018, 01:05 AM   #2572
mitchba is offline mitchba  Canada
mitchba's Avatar
maybe GitHub?
Old 8th November 2018, 12:06 PM   #2573
pos is offline pos  Europe
pos's Avatar
I will check, thanks for the suggestion Mitch!
2019-01-16: rePhase 1.4.3
Old 8th November 2018, 01:02 PM   #2574
3ll3d00d is offline 3ll3d00d  United Kingdom
3ll3d00d's Avatar
I use GitHub to distribute release binaries via the releases feature, details in Distributing large binaries - User Documentation
Old 9th November 2018, 08:41 AM   #2575
Osho1964 is offline Osho1964  Italy
hello to everybody,
I am new to Rephase, sorry if the question as been already answered.
Is there a way to import IR generated by Rephase into Analog Device SigmaStudio software?
Trying to use FreeDSP to correct the phase response of Earphones.
Thank you.
Old 1st December 2018, 12:56 AM   #2576
pos's Avatar
Hello Osho1964, sorry for the delay.
I know it has been done several times before, but I don't know which format should be used.
"32 / 64 bits floats lines (.txt)" is probably a good one to try first.
Old 1st December 2018, 01:05 AM   #2577
pos's Avatar
Originally Posted by pos View Post
I received a message today from sourceforge telling me that the rephase project was infringing their term of service because no source code was made available.
rePhase is free software, but not open source, and I intend to keep it that way.
As a consequence I will have to remove it from sourceforge and find another hosting solution that accepts binary-only software.
I will keep you informed, and I hope I will be able to maintain the sourceforce project page alive in order to point users to the new hosting solution.
rephase.org is now online: rePhase
It is a quick and dirty port of the info that was on the sourceforge project page. Consider it a first draft
Please tell me if it works for you.
If it does I will remove all binary files from the sourceforge project and put a link to the rephase.org website in the description.
Old 1st December 2018, 02:12 AM   #2578
mitchba's Avatar
+1 Way to go Thomas!
All the best,
Mitch
Old 2nd December 2018, 12:00 PM   #2579
Kreisky is offline Kreisky  Italy
... hello, I've downloaded rePhase on W10 64bit but I cannot install it, rePhase services try to start and then they stop, no problem instead with an old Windows XP.
... maybe the problem is on my notebook...
Marco
Cairn FOG2 - My_ref C - DIY speakers
Old 2nd December 2018, 12:19 PM   #2580
pos's Avatar
Cleaning your temporary files should solve the problem
rePhase, a loudspeaker phase linearization, EQ and FIR filtering toolHide this!Advertise here!
FIR linear phase plugin for MiniDSP? diyjb01 miniDSP 17 9th June 2016 02:35 PM
FIR filter design tool for Loudspeaker magnitude equalization ttmusic Software Tools 3 24th May 2013 09:30 PM
FIR Filtering experiences Olombo PC Based 8 10th February 2013 04:45 PM
AVX based FIR VST, crossover / EQ / DRC and delay KOON3876 PC Based 97 26th November 2012 08:18 AM
Phase EQ using FIR filters Grasso Multi-Way 2 2nd July 2003 11:37 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
