rePhase, a loudspeaker phase linearization, EQ and FIR filtering tool
Old 8th September 2017, 02:42 PM   #2171
torgeirs is offline torgeirs  Norway
I don't think perfect square wave output is very important as we can tolerate quite a lot phase distortion, but a square wave input is aparantly one of the most revealing signals for audible distortion and artifacts.
Old 8th September 2017, 04:07 PM   #2172
wesayso is offline wesayso  Netherlands
wesayso's Avatar
Seeing as how many people can tolerate a lot of things that I have a different opinion about, that does not mean that much to me. Which is why I went on to pursue such a thing and make up my own mind. No regrets yet.
Use Science to design your speakers and they will sound like a piece of Art...
Old 8th September 2017, 04:36 PM   #2173
Davey is offline Davey  United States
Most people who've audibly evaluated phase distortion haven't done it correctly anyways.
Pursuing something and making up your own mind is fine and dandy....as long as you understand all the variables involved and the comparison is valid.
Dave.
Old 8th September 2017, 05:47 PM   #2174
Just wanted to join the promoting of the square wave as an revealing test signal for auditory tests. (Regardless of phase distortion standing) ;-)
Old 9th September 2017, 03:30 AM   #2175
Jim the Oldbie is offline Jim the Oldbie  United States
Jim the Oldbie's Avatar
Dave, as I am a likely member of the above group (safe bet), I wonder if you or anyone might have suggestions as to what I might do differently from this test I ran awhile back:
I looked at a square wave output (~300 Hz) from one of my sealed 2-ways on a stand, with my measurement mic about a meter away at tweeter level. Needless to say, the output bore no resemblance to the input.
I then constructed a convolution with rePhase, accounting for the LR8 crossover slopes, F3 and sealed alignment, simply attempting to un-twist the electrical/mechanical phase respone. To my surprise, the measured waveform became recognizably square-like; obviously band-limited, and with spectral errors, but by god if you squinted a little, it was a square wave!
The catch, as you might guess, is that this corrected output sounded exactly the same to me. That includes the square wave, and any music I could come up with to try to reveal any differences.
I was kind of amazed by this. If I have it right, the LR8 xover alone was applying a whopping 720 shift. And the visual evidence was pretty unassailable - there was definitely something "wrong" before, and it sure looked "fixed" after.
Did I miss something here? Is there anything else I might try in order to hear this better?
Sorry if this is boring, this stuff is likely rudimentary to most of you. Still, any thoughts or suggestions are appreciated.
Jim
Old 9th September 2017, 03:52 AM   #2176
Select three or four well-recorded pieces from your music library and get them onto a computer....if not already.
Make sure they don't have any musical peaks above about -3dbFS. If they do, scale them lower so they don't.
You need to do this because processing via an appropriate crossover will increase the peak levels a bit. (You don't want clipping to be a variable.)
Make an exact copy of each and then process each copy with the appropriate all-pass function for the crossover you're interested in. (Example: LR4 would be a 2nd-order all-pass.) You can use Goldwave or similar.
Listen to the original and processed copy without knowing which is which. It's easiest with headphones, but you could use a normal set of speakers also.
Dave.
Old 9th September 2017, 03:55 AM   #2177
Thanks a lot Dave, I'll try it with the Foobar ABX plugin this weekend if I have time.
Jim
Old 9th September 2017, 05:14 AM   #2178
fluid is offline fluid  Australia
Dave.
Wesayso's approach to phase manipulation/correction is quite different in some ways to linearizing the phase turn from a crossover filter. And that difference is important when discussing the conclusion or if the evaluation method is valid.
I have built a speaker similar to his and used a correction filter based very heavily on his where there is Excess phase correction up to 1K. The correction aims to follow the generated minimum phase of the frequency response at the listening position. There is a very audible change in the sound of the bass when changes are made to the amount of phase correction or if it is removed completely. This is more room correction (or room speaker interaction) than pure speaker correction. I have never tested the same sort of correction on any other speaker to know if the result is the same but on my line array the difference is clearly audible.
This is the change in phase when viewed through a 6 cycle FDW. There are always arguments as to whether this is the "right" way to go but I find it hard to believe that other's could not hear what I am hearing in the same situation.
rePhase, a loudspeaker phase linearization, EQ and FIR filtering tool-vs-phase-jpg
Jim what does the phase of your speaker look like at your listening position with and without the correction? Testing at 1m metre might not help you because the room will mess up the phase and then it becomes hard to hear the difference between two different messes
Old 9th September 2017, 05:58 AM   #2179
I'm afraid I haven't taken any measurements of my main speakers at the listening position. My approach to this setup thus far has been conservative driver correction (derived from quasi-anechoic testing) + baffle step comp for the satellites, and room correction + Linkwitz transform for the 2 sealed subs.
Last but not least, a "room" curve, arrived at over time via subjective listening. This ended up being a gentle tilt downward from 32 Hz to 16 Khz @ -0.5 dB/oct, for a total of -4.5 dB using 3 cascaded low-Q shelving filters. Everything is IIR using miniDSP.
I've been so pleased with the sound I'm getting, and so busy with other things (stupid day job!) that I haven't gone any further down the rabbit hole - yet. But I do understand the "2 messes passing in the night" scenario you describe - I'll keep that in mind going forward.
Jim
Old 9th September 2017, 07:43 AM   #2180
Measurements at the listening position will be a good place to start to understand the impact of any changes you make. Even if a measurement might not tell the whole story its still a good indicator.
I have found that spatially averaged impulse measurements like those that were mentioned by Swiss Bear to be a good base for room correction.
Your approach sounds sensible. I have about twice the slope of yours on the arrays at near 1dB/octave but that is quite speaker (directivity) dependent as on LX521 I like less tilt.
rePhase, a loudspeaker phase linearization, EQ and FIR filtering toolHide this!Advertise here!
FIR linear phase plugin for MiniDSP? diyjb01 miniDSP 17 9th June 2016 02:35 PM
FIR filter design tool for Loudspeaker magnitude equalization ttmusic Software Tools 3 24th May 2013 09:30 PM
FIR Filtering experiences Olombo PC Based 8 10th February 2013 04:45 PM
AVX based FIR VST, crossover / EQ / DRC and delay KOON3876 PC Based 97 26th November 2012 08:18 AM
Phase EQ using FIR filters Grasso Multi-Way 2 2nd July 2003 11:37 PM
Copyright ©1999-2019 diyAudio
