rePhase, a loudspeaker phase linearization, EQ and FIR filtering tool
Old 6th September 2017, 06:16 PM   #2161
mark100 is offline mark100  United States
Originally Posted by fluid View Post
Have you tried cascading another filter at the same frequency in the OpenDRC to get a higher slope. IIR slope plus filter linearization to keep the latency down. LR4 from the Linea and LR4 from the open DRC should get you LR8 overall.
Yes, thanks. Tugging and pulling at lot's of combos
Old 6th September 2017, 06:46 PM   #2162
GDO is offline GDO
GDO's Avatar
Originally Posted by BYRTT View Post
Right if its science for our hearing but that front also moves from time to time, regarding real world wave shapes i can do my own science and see output verse input is hopeless distorted no matter what we hear .
Wave shape output 50Hz SQ wave from a DC - light-speed domain:
Wave shape output 50Hz SQ wave from summed DC - 500Hz pass-band with a 2nd order LR XO point then 500Hz - light-speed pass.band:
Wave shape output 50Hz SQ wave from a 20-20kHz domain:
Wave shape output 50Hz SQ wave from summed 20 - 500Hz pass-band with a 2nd order LR XO point then 500Hz - 20kHz pass-band:
Oh nooo, not the squared (head...) wave test agaiiin...
"Fitz: I want to use an 8 inch woofer for more bass and a dipolar ribbon tweeter for sweet highs. And the enclosure should be a box with a vent, like everybody uses." S.L. Conversations with Fitz https://www.youtube.com/watch?v=59C7KZ5i42A
Old 7th September 2017, 11:53 PM   #2163
In all my experience, science and listening agree.......
perfect magnitude response,
perfect phase response,
perfect impulse response,....
perfect square wave response......
get any ONE of them right, and ALL the others are right too.
It is truly glorious, how getting any one of them right,.... sounds
Old 8th September 2017, 01:55 AM   #2164
Jim the Oldbie is offline Jim the Oldbie  United States
Jim the Oldbie's Avatar
Smooth magnitude response FTW (as the kids say)!! Enjoying some right now. Even more fun if it magnitudes right down to 16 Hz, wheee!
Jim
Old 8th September 2017, 06:44 AM   #2165
silverprout is offline silverprout  France
silverprout's Avatar
It is utterly funny to see the propagation of the generalisation of this kind of idea.
I rarely see CSD graphs... some people seems to have equalized perfectly their loudspeakers system but the CSD shows that their hear more resonances than audio signal.
Things I Should Have Learned In School (But Probably Didn't)
Old 8th September 2017, 09:24 AM   #2166
torgeirs is offline torgeirs  Norway
"mark100:The windowing also alters the steepness of the filter vs number of taps: Think I found lanscoz window (sorry for missspelling) had the highest oct/db vs taps. There may be "better" windows out there or in RePhase?
Old 8th September 2017, 10:11 AM   #2167
BYRTT is offline BYRTT  Denmark
BYRTT's Avatar
Think can follow what you mean but can also follow what mark100 mean and actual pages back he shared nice CSDs, don't know if its rarely but up front below two-wayer correction clean up CSD.
Old 8th September 2017, 12:37 PM   #2168
Hi, what does CSD stand for ?
Fwiw, I meant perfect responses in anechoic type environment. ..
I tune my speakers outdoors for closest substitute.
I've found that magnitude, phase, impluse, and yes ..I've even looked at square wave response...........I've found they all move together...fix one, and others get fixed...that's my real point here ....
But more importantly, sound improves. Hardest test of all imo, is off axis square wave response
Old 8th September 2017, 12:47 PM   #2169
pos is offline pos  Europe
pos's Avatar
Agreed, resonances will show as decays on a CSD, and as a bumps or dips in the magnitude response.
This is just a matter of using the correct visualization for what you want to show (or hide ).
waveTracing | rePhase
Old 8th September 2017, 01:05 PM   #2170
You can't fix resonances, the only cure is to d'ont trigger them.
When i tune my multi-sub configuration, i use pure tones and band passed white noise... a 50Hz pure tone can give a flat FR response at 0dB from 20 to 200Hz.
rePhase, a loudspeaker phase linearization, EQ and FIR filtering toolHide this!Advertise here!
FIR linear phase plugin for MiniDSP? diyjb01 miniDSP 17 9th June 2016 01:35 PM
FIR filter design tool for Loudspeaker magnitude equalization ttmusic Software Tools 3 24th May 2013 08:30 PM
FIR Filtering experiences Olombo PC Based 8 10th February 2013 03:45 PM
AVX based FIR VST, crossover / EQ / DRC and delay KOON3876 PC Based 97 26th November 2012 07:18 AM
Phase EQ using FIR filters Grasso Multi-Way 2 2nd July 2003 10:37 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
