rePhase, a loudspeaker phase linearization, EQ and FIR filtering tool
Old 1st April 2017, 12:55 PM   #1811
ropf is offline ropf
Originally Posted by torgeirs View Post
With some engines two fir filters can be cascaded so this can be realized.
Or could the delay and LP filter be convoluted with he HP filter to make a single that does the same?
Basicly both does the same. There may be interference arifacts caused by the limited tap length of the first filter convolved with the same type artifacts of the second filter ...
I think it's better to convolve "perfect" low- and hipass and run the tap reduction afterwards on the resulting bandpass.
Old 1st April 2017, 01:55 PM   #1812
mark100 is offline mark100  United States
Originally Posted by fluid View Post
The OpenDRC isn't going to write to file as it is not a computer device.
I would capture at the entry to the amps as that is the last place the signal will differ and recording a line level signal is much easier than needing to use an attenuator to measure the output from the amplifiers.
You could record the test file into REW or if it is digital you could just get Jriver to write the file as it should be the same and run a comparison on that.
Another good test would be to run the same convolution on both setups and see if you can tell a difference then. That way you remove one more difference from the setup.
Whenever you have more than one variable change how can you know which one it was that you liked more?
I have listened to a few comparisons of A/D conversions vs original and I find it very hard to tell which is which, extra conversions should be avoided if possible but one extra really doesn't seem to do that much harm as long as the converter is decent.
Another thing to consider is level matching in that only a slight difference in output can lead to preferring the sound of the louder one. Very hard to get a true A/B between devices without a lot of effort spent on level matching.
Hi Fluid, thx.
Yeah, isolating variables....not always easy..but i do have to say it is one of my stronger abilities
One variable that is a problem to isolate, is that amp entry isn't the same. With PC convolution I need to use analog entry into ICE amps, with openDRC I get to use digital. There's no question this penalizes the PC conv, at least in terms of an audible noise floor.
I don't have any difficulty with measuring attenuated amp outputs...as every amp I own has gain control. Heck, I measure them so regularly I bought some speakon to XLR adapters. So, I think I'll try to run a transfer function against ICE outputs, PC vs DRC. Just hoping that sync through the two paths is close enough to allow capture.
I should have mentioned earlier that I'm using the same rePhase files in both cases, just changing the number of taps used. I even tried restraining PC conv to 6144 taps/channel for comparison's sake. But in my mind, the the real reason for wanting PC conv is for more taps to play with. The DRCs are just so dang flexible, other than being tap limited.
I'm very aware of level matching, and just as important i think, is relative level matching between drivers' passbands if that becomes a variable due to different routing/amp configs. I can hear a 1-2 db difference in balance between subs and mains, a little easier than an overall 1-2 spl diff, I think.
I should admit I don't really try to A/B much anymore...I don't trust it. My ears, my mood, the weather, my girlfriends mood haha, all seem to make my ears wander preferentially. I like to just listen for a few days to all kinds of music, ....in the focus zone as well as wandering through the house listening from different rooms...a technique often very telling IMHO.
So like I said, I shouldn't even have mentioned a preference...sorry folks.
But that said, I do like the openDRCs.....
Old 1st April 2017, 01:55 PM   #1813
pos is offline pos  Europe
pos's Avatar
The reason is the tests in this thesis that suggests that long fir (regardless of dsp platform) can give audible distortion!
For a given response target the more taps you have the better.
Brickwall filters are another story, as the more taps you have the steeper the slope, but that is kinda taking the problem upside down...
2019-01-16: rePhase 1.4.3
Old 1st April 2017, 02:17 PM   #1814
Pano is offline Pano  United States
Pano's Avatar
Seems simple to compare CPU vs openDRC. Just write to file with JRiver, record the AES or SPDIF signal from the openDRC and compare them. Everything else is superfluous. If those two are the same, or very, very close, then the audible differences lie elsewhere.
Take the Speaker Voltage Test!
Old 1st April 2017, 02:21 PM   #1815
Pure noob here must learn how to write to file in JR, how to record AES from openDRC, and then how to compare.......
Happy to learn....pointers, links?
thx, mark
Old 1st April 2017, 02:42 PM   #1816
wesayso is offline wesayso  Netherlands
wesayso's Avatar
In JRiver you can set it to write to a file where you configure your soundcard. So instead of pointing at a soundcard you set it to write to file (Disk Writer).
Playback options > Audio Device > Disk Writer (might have to press the "more" option to find it near the bottom of the list).
There's so much that can be slightly different between the two options you used. Seeing it in a measurement would help identify what was different.
More tabs used sounds like a good explanation of possible differences but if you did encounter the same with the shorter FIR filter on the PC, we'd have to dig a little deeper.
I'd also do a loop back with the PC setup to "see" how clean the IR of the soundcard performs. So basically routing the soundcard or DAC out back into the line in and record an REW sweep.
Use Science to design your speakers and they will sound like a piece of Art...
Old 1st April 2017, 02:50 PM   #1817
BYRTT is offline BYRTT  Denmark
BYRTT's Avatar
...The reason is the tests in this thesis that suggests that long fir (regardless of dsp platform) can give audible distortion!
http://lib.tkk.fi/Dipl/2008/urn011933.pdf#page61...
All 75 pages in that pdf document study would take long time to read i could be misunderstanding what you point is but can see in their chapter 7 conclusions quoted below that you should be good to go in that your used filters is much lower in order.
Rough safety limits according to both test methods would be to keep the order of a linear phase
FIR crossover filter under 600 at higher frequencies (1 and 3 kHz) to prevent from the ringing
phenomenon producing audible errors. At low frequencies, such as 100 Hz and 300 Hz, the
order may be up to thousands, and still no audible errors will occur.
Old 1st April 2017, 08:55 PM   #1818
torgeirs is offline torgeirs  Norway
The explanation of the artifacts that can be heard, is the time lag off axis between two speaker elements eg tweeter and mid.
Long fir filters creates a long preringing and the time delay between the filters off axis, because of different path lengt to the ear, cause interference that can be heard. Even at as low as 0.5 milliseconds difference in path length. (acording to the thesis)
A single driver will NOT produce the artifacts if not a time delay between the filters are introduced. (The headphone test)
A steep BP filter at 600 Hz and 3k needs a lot of taps (4k taps?)
So then I think that the 3k LP filter has the same preringing as the 600HP filter, that is the preringing as a 4k tap filter. (And that is much longer than a 700 tap filter.)
Or does rePhase only use the taps it needs when making the 3k LP part of the BP filter. That is: The preringing of the 3k filter (in the 600 to 3k BP filter) is much less than 4k/2 = 2k samples?
(On a sidenote i'm very suprised that preringing artifacts can be heard. But maybe the ear is more sensitive to difference signals? Ref tuning an instrument by listening to the pitch difference between two instruments)
Old 1st April 2017, 09:46 PM   #1819
silverprout is offline silverprout  France
silverprout's Avatar
This is perhaps stupid but...
Since I can hear the artifacts with sine waves pure tones (pretty easy to verify) it should be perhaps useful to test (or not) the filter settings with pure tones before theorizing too mutch ?
(less headaches for idiots like me)
Things I Should Have Learned In School (But Probably Didn't)
Old 1st April 2017, 11:45 PM   #1820
BYRTT's Avatar
torgeirs,
Is there really anything to worry about, look post 1817 and see the quote from their paper where they write that at high frq orders under 600 prevent ringing and at low frq orders up to 1000 is okay.
How steep in orders do you like to go for example LR 48dB/oct is 8th order and 96dB/oct is 16th order and far below orders of 600 or 1000, in Rephase there is also other than symetric LR filters to choose from, for example below show 8th order non symetric "Reject low" and "Reject high" which filter 8th order for one part and 16th order for the other part, but there is many more models "Overlapping 1/2 oct" / "Overlapping 1 oct" / "Overlapping 2 oct" / "Overlapping 3 oct" / "Hornbach-Keele" / "Hornbach-Keele last".
rePhase, a loudspeaker phase linearization, EQ and FIR filtering toolHide this!Advertise here!
FIR linear phase plugin for MiniDSP? diyjb01 miniDSP 17 9th June 2016 02:35 PM
FIR filter design tool for Loudspeaker magnitude equalization ttmusic Software Tools 3 24th May 2013 09:30 PM
FIR Filtering experiences Olombo PC Based 8 10th February 2013 04:45 PM
AVX based FIR VST, crossover / EQ / DRC and delay KOON3876 PC Based 97 26th November 2012 08:18 AM
Phase EQ using FIR filters Grasso Multi-Way 2 2nd July 2003 11:37 PM
Copyright ©1999-2019 diyAudio
