Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Multi-Way Conventional loudspeakers with crossovers |
#1731 |
I thought they are the same thing....
make sure to unload the FIR file and send to dsp, before loading a new file. That might be why you're getting strange numbers...files adding together?? And I would definitely use the 48K plugin... |
#1732 |
Have changed to the 48k plug in. It still says there are too many coefficients. Seems the coefficients need to match the number of taps.
Only way to make this work is to set a real small number of taps in Rephase. I'm doing something wrong for sure... Sent from my Moto G (4) using Tapatalk |
#1733 |
When in FIR Filter (in any channel) 4x8 or 4x8/96:
- choose File mode - BEFORE you Browse/Load/Send to DSP your intended filter, you must enter manually the number of taps in the "Taps used" field , in the lower right corner above the "Taps Available". - You need to enter the number which is equal to or higher than the number of taps your filter uses. Program will inform you that if you have "spare" taps unused, it will fill them as zero.... - After this, you can download and "Send to DSP", AND then unclick "Bypass" - Lastly: tap=coefficient AFAIK Draki Last edited by Draki; 7th February 2017 at 12:38 PM. |
#1734 |
Thanks Dealing
Yea did that.... redid the rePhase with 1024 taps, set taps used to 1024 and selected the filter file. Same message, too many coefficients. Try again. uploadfromtaptalk1486474068534.jpg Sent from my SM-T800 using Tapatalk Last edited by nzlowie; 7th February 2017 at 01:35 PM. |
#1735 |
Are the rePhase files 32 bits IEEE - 754 mono (.bin) ?
That's the only one I know to work in plugins.... |
#1736 | |
EDIT: Mark100 already posted the correct file format//// |
#1737 |
Cheers guys, I knew it must be something that I was doing wrong!!!
Wrong file formats! Now I know it loads I'll try again.... Thanks Sent from my SM-T800 using Tapatalk |
#1738 |
I agree with WESAYSO. For low frequency, low tap FIR is not recommended. 262144 is my current impulse length. That's the max number I can do with my computer, but I wish I can make it higher in the future. Digital technology is still very immature.
![]() Last edited by plasnu; 8th February 2017 at 07:07 PM. Reason: Typo |
#1739 |
FYI, Behringer has a b-stock UMC1820 for $235 at Ebay 182288043960
I bought the 1st and now need to order a mic. Only 2 refurbs since initial November batch has me optimistic. |
#1740 |
Is anyone have measured the UMC1820 rmaa performance ?
Things I Should Have Learned In School (But Probably Didn't) |
Thread | Thread Starter | Forum | Replies | Last Post |
FIR linear phase plugin for MiniDSP? | diyjb01 | miniDSP | 17 | 9th June 2016 02:35 PM |
FIR filter design tool for Loudspeaker magnitude equalization | ttmusic | Software Tools | 3 | 24th May 2013 09:30 PM |
FIR Filtering experiences | Olombo | PC Based | 8 | 10th February 2013 04:45 PM |
AVX based FIR VST, crossover / EQ / DRC and delay | KOON3876 | PC Based | 97 | 26th November 2012 08:18 AM |
Phase EQ using FIR filters | Grasso | Multi-Way | 2 | 2nd July 2003 11:37 PM |
New To Site? | Need Help? |
