rePhase, a loudspeaker phase linearization, EQ and FIR filtering tool
Old 4th January 2017, 08:05 PM   #1441
pos is offline pos  Europe
pos's Avatar
Originally Posted by mark100 View Post
Downsampling would be nice...
....and I take it you mean to allow for implementations in a Four-Audio type way....? Four Audio | FIR Filters: calculation power, length of impulse responses, and frequency resolution
I kinda made the same suggestion https://www.minidsp.com/forum/sugges...le-rates#27931
Four-Audio approach is more complicated and evolved than what I propose, as this would only be a matter of running the input SRC, DSP and ouptut at 32kHz.
I don't think 22kHz or lower would be possible with this approach as many DAC seem to limit accepted sampling rate range to 32kHz.
The plate amps do look very interesting for a small two-way....I guess as long as the crossover is high enough. For my 650Hz crossover point, 300 taps struggles a little with the slope I'd like to use. It would be nice if the plugin allowed a little flexibility here....
Indeed, but it is perfect for a ~2kHz crossover point, and you can still use a few of the available biquads to help with the filters or EQs.
What version do you have?
2019-01-16: rePhase 1.4.3
Old 5th January 2017, 01:48 AM   #1442
mark100 is offline mark100  United States
Hi POS, I have the 250 version.
The Four-Audio approach in one miniDSP unit isn't what I meant.
I meant your approach. So we can mimic what Four-Audio does, by using multiple miniDSP units running at different sampling rates.... like you described in the link you gave previously.
Old 5th January 2017, 06:59 AM   #1443
pos's Avatar
I see
devteam responded to your suggestion that they "might have something even better planned".
It is probably some sort of FFT convolution with a large number of taps.
Let's wait and see, but this kind of convolution invariably add some more delay, and is also more prone to implementation errors.
I wish there was an hardware/DSP convolution unit on the market powerful enough to do temporal convolution with a large number of taps without having to use decimation or FFT strategies...
Old 5th January 2017, 09:41 AM   #1444
Kjeldsen is offline Kjeldsen  Denmark
What about the pro audio DSP audio interfaces? They come i several price ranges, but I don't know how powerfull the DSP's are, but some of them seems to be quite powerfull and expensive. You will ned a PC og Mac to program it, but otherwise they will work stand alone.
http://kjeldsensforbindelser.dk
Old 5th January 2017, 12:55 PM   #1445
I don't what decimation or FFT strategies mean, but whatever you say, ....I'm for
Old 5th January 2017, 01:05 PM   #1446
I don't know of any pro-audio interfaces that have the FIR capability of even the smaller miniDSP units.
Pro-audio usually can't tolerate much latency, so big FIR blocks don't make a lot of sense in speaker management processors.
If you know of any, please link...very interested...
Here's a good post listing some current alternatives. The Xilica at the bottom is typical of pro units that I've seen specs for. https://www.minidsp.com/forum/opendr...tstart=0#21877
Old 5th January 2017, 01:27 PM   #1447
mwmkravchenko is offline mwmkravchenko  Canada
mwmkravchenko's Avatar
I know for sure that Marani has FIR capability. And I'm pretty sure there are others.
Mark
www.kravchenko-audio.com
Old 5th January 2017, 06:13 PM   #1448
BYRTT is offline BYRTT  Denmark
BYRTT's Avatar
Nice chart BYRTT,
I've stopped everything until I sort out what the sound cards are unexpectedly contributing...will report back....
16 bit Behringer UCA222/UCA202 think is great value and probably good enough as measurement interface as seen below at 48kHz.
Old 5th January 2017, 07:03 PM   #1449
I haven't tried any myself, but here is one example
Four Audio | HD2
They sell them with frontpanel controls and without (black box), and they have an high end hifi version. They also sell the boards without connectors and chassis - but you probably should buy a lot.
Old 6th January 2017, 11:30 AM   #1450
Thanks for the replies everyone,
The Marani stuff looks nice...I had not heard of them. I see their units max out at 1024 taps per channel.
Not surprising again, given pro-audio's inability to live with much latency.
Yes, the Four-Audio HD2 is a unique solution, but very $$$$....
The UCA222/202 caught my attention for sure!
But I really need XLR / phantom power for most of the measurements I make.
Anybody measured or seen measurements for a really clean, reasonably priced, conventional mic soundcard?
After measuring the three alternatives at my disposal... behringer UMC404, UMC1820, and X-32...I've decided the x-32 is the cleanest.
Hopefully will post new speaker measurements that include the sound card's starting (negative) contribution, later today.
rePhase, a loudspeaker phase linearization, EQ and FIR filtering toolHide this!Advertise here!
FIR linear phase plugin for MiniDSP? diyjb01 miniDSP 17 9th June 2016 01:35 PM
FIR filter design tool for Loudspeaker magnitude equalization ttmusic Software Tools 3 24th May 2013 08:30 PM
FIR Filtering experiences Olombo PC Based 8 10th February 2013 03:45 PM
AVX based FIR VST, crossover / EQ / DRC and delay KOON3876 PC Based 97 26th November 2012 07:18 AM
Phase EQ using FIR filters Grasso Multi-Way 2 2nd July 2003 10:37 PM
Copyright ©1999-2019 diyAudio
