The horns are all designed now, I am drawing the molds up on AutoCAD now ready to send off to a place with a 5 axis CNC router.
Does anyone know of an effective way to draw these in AutoCAD using output data?
Thanks,
Ryan
Using output data from what?
Not familiar with using autocad in 3D, but if similar to Solidworks or Unigraphics l would revolve a 2d sketch of the horn. Then to create
the mould subtract the horn from a half solid block.
Lusk is helping me by drawing up the horns in a CAD program for the company that is making the molds for me.
One thing that I am considering adding to the mold, to make it easier is this:
The red bit is an addition to the mold, just to make a base a bit stronger for it to sit on. The flaps that are circled are so that the edges of the horn have straight edges, and so I can cut back excess fibreglass back from where no one would see it.
Now what I am wondering is, will this sharp edge be detrimental? As sound will re-radiate from the hard edge. Should I instead round it over? Or just use the sharp edge?
Thanks,
Ryan
Thanks,
Ryan
Hi Del,
I am attempting an Avant Garde Clone, but it is hard to tell a lot of the time how they go about certain things, I sent these off to the CNC place with a roundover in the design.
For your horns, do they look like a radius roundover, or do they follow the equation of the horn function? Once again, hard to tell in pictures.
Thanks,
Ryan
Thanks,
Ryan
Hi Gregg,
Not much has been happening with these at the moment, the place that is doing the machining couldn't get the molds done for me in time for when I wanted them done. So I have been working on some other projects in the mean time.
However I have access to machinery at uni now, so I may have some more happening on these soon.
If you ever need a hand lifting, assembling, etc you know where to contact me, I also have my measurement Mic and minidsp now, plus 2 of my 2 channels are complete and I have a PA 8 Channel amp too
Ryan
Ryan
Here's my latest....finished this on Saturday...Azura 160, 340 and 550. Faital Pro 18 inch subs.
Very cool. Can I ask: are you married? ;-)
Ha. These are for a young gent, who's not married...though they fit very well in his modern house.
Mine are more discrete...same Azura 340...but not the big 160.
- Ideas for Avant Garde Trio Clone
