Old 12th July 2012, 05:09 AM   #31
chlorofille is offline chlorofille  Malaysia
chlorofille's Avatar
For a start, the Scanspeak D3004 Beryllium!
Old 12th July 2012, 07:41 AM   #32
gornir is offline gornir  Sweden
gornir's Avatar
Originally Posted by 5th element View Post
With regards to the large peak @ 27kHz finding its way into the harmonic distortion via resonance amplification, this is an issue in mid/bass drive units, but I think it's much less of an issue in tweeters as the harmonics produced are higher then what we can hear. The only way these could be audible is via the creation of IMD products.
I agree with you that this kind of cone break-up for a mid-woofer would be a major issue that would have to be dealt with. The DXT tweeter has one of the sharpest cone break-ups I’ve ever measured and it contributes to a rise of about 8 times in the distortion profile for the third-order harmonics at 9kHz. Unfortunately with my measurement setup I cannot catch this, but I’ve seen other measurements done for this tweeter that shows the effect. One such is the German DIY magazine “Hobby & Hifi” issue 2010/1.
I also think that this effect shouldn’t be exaggerated, but some people are sensitive to it, others aren’t. I think it’s up to each and everyone to listen and see if it’s an issue or not and do their own conclusion. This was my main point with pointing it out. The DXT tweeter is a great driver, but it might not fit everyone’s sonic preferences.
Originally Posted by gainphile View Post
I am a metal-cone kind of guy and aware of their 'issues'. In my ears the distortion numbers in higher frequency is no problem. But I dislike phase plug, hence where the DXT fits in! My "best" tweeter so far is Vifa DQ25 with phase shield removed. Sounds great except that resulting massive null at 15khz.
So as I really hope the Seas DXT will be a very nice compromise between smoothness and directivity . I'll report ...
The DXT tweeter is a great driver and I think you will be happy with it.
Göran, come on.. spill the beans. What are these tweeters you prefer over the DXT
I’ve used so many tweeters over the years, but if you force me to answer and I compare it with some tweeters I’ve recently used. This is my current favorites:
1. For twice the money ScanSpeak D3004/660000 (a class of its own)
2. For the same amount of money ScanSpeak D2608/913000 “HDS”
3. For less money Dayton Audio RS28F-4 (a good contender to the DXT)
As you can see, none of these are “metal” tweeters.
Yes, I’ve also used the ScanSpeak Beryllium lately, but it’s so expensive so it’s not fair to compare it and it has a unique sonic character that is hard to compare with other hard dome tweeters and soft dome tweeters. I think this is a kind of tweeter you either love or hate, so to speak.
/Göran
Author of the "AudioExcite Loudspeaker Design" website & Technical Consultant for HULGICHAUDIO
http://www.audioexcite.com http://www.hulgichaudio.com.au/
Old 12th July 2012, 10:35 PM   #33
5th element is offline 5th element  United Kingdom
5th element's Avatar
Indeed and if one played a 9kHz tone through the DXT, the tweeter would generate a third harmonic at 27khz and this would then be amplified by the domes bell mode resonance. We cannot hear this though.
The only way this can be audible in any way would be through the generation of difference tones through IMD. It would be interesting to throw some worst case scenario test signals at the DXT just to see how much of an issue this could potentially be.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 13th July 2012, 12:58 PM   #34
gainphile is offline gainphile  Australia
gainphile's Avatar
Well I didn't have to wait long. Gotta love Madisound and USPS
It was pretty easy to equalise them to flat actively, just a simple notch centered at around 4khz. I had not bothered to fine tune them yet as they are still surface mounted. But my first impression is very clean, neutral sound.
Looks great too!
http://gainphile.blogspot.com
Old 17th August 2015, 11:25 AM   #35
satefan1973 is offline satefan1973  Netherlands
I am thinking of applying the prestige two filter to my in iDunn (same tweeter but with the U18RNXP (bigger brother of the woofer used in this one). The cross-over in the prestige two is simpeler and crossed a bit higher. Anyone tried this? Or has thoughts on it?
thanks,
Old 3rd October 2018, 08:20 PM   #36
Brumel is offline Brumel  Sweden
Big bump on this thread. I have bought myself a pair of these wave guides. They look the business for sure. I have a mixed bag of experience with wave guides. Thinking of the Monacor 300WG I don't think I got the crossover to work properly which resulted in vague stereo focus.
The rise in the presence band raises some concern with WG's.
Isn't the 27B/G DXT best suited for a narrow baffle design? Because the diffraction edges of the wave guide helps to fill out the drop in baffle support a narrow design would result in the end result would be a flat respons easily mated with the mid/bass unit.
I'm going to put my 27mm all dome with the DXT lens on top of a bass/mid enclosure mounted in its own tweeter housing. I have built a prototype.
WTB SEAS Prestige 27TBCD/GB-DXT poler Swap Meet 3 28th September 2011 02:22 AM
SEAS DXT tweeter and integration.. Elbert Multi-Way 1 13th October 2009 10:46 PM
My Seas DXT + SS18W speaker ojg Multi-Way 29 15th January 2009 07:44 PM
FS: Seas 27TBCD-DXT - new waveguide tweeters Tenson Swap Meet 3 7th July 2008 11:53 PM
27TBCD/GB-DXT as an alternative to 27TBFC/G AntM Multi-Way 2 16th June 2008 11:03 PM
