X-over Phase shift question
Old 29th May 2012, 05:42 AM   #1
kiwilistener is offline kiwilistener  New Zealand
Default X-over Phase shift question
I'm considering the types of 2nd order 2 way crossover to use in a new setup.
Most designs suggest reversing the polarity to negate most of the phase shift.
My question is , is that for the woofer only or does the tweeter polarity need to be reversed as well? Does this apply to the crossover or speakers only?
Old 29th May 2012, 09:00 AM   #2
AllenB is offline AllenB  Australia
There are several ways it could be done but the standard way is to simply reverse the connections at the tweeter.
If you were to reverse the woofer as well, you'd be back where you started
Old 29th May 2012, 10:49 AM   #3
system7 is offline system7  United Kingdom
system7's Avatar
Tweeter phase is a very moveable feast. It so depends on the alignment and offset between the woofer and tweeter, which most speaker design simulators allow you to adjust.
The object of the exercise is to keep the two driver's phase tracking near crossover. This makes for good imaging and avoids suckouts in the frequency response.
On a conventional baffle you normally wire in phase. If you time align, as below, out of phase is going to work better:
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
It all greatly depends on how far apart the acoustic centres of the two drivers are. Hopefully a good kit design will have done all this work for you.
Best Regards from Steve in Portsmouth, UK.
X-over Phase shift questionHide this!Advertise here!
Phase Shift PWM Andrew Eckhardt Class D 6 14th November 2010 07:56 AM
Corrective circuit phase shift? prickears Multi-Way 14 30th July 2010 03:46 AM
Why am I getting a positive phase shift sigpl Solid State 22 29th December 2009 04:31 PM
Phase shift smps topology darkfenriz Power Supplies 12 10th August 2008 11:30 AM
Zero phase-shift gareth Solid State 11 9th May 2008 04:45 PM
Copyright ©1999-2019 diyAudio
