Speaker testing without anechoic chamber
I'll revive this thread to ask what kind of measurements is this guy doing.
Starting from around the 14' mark. Basically he is suspending the microphone from a plastic tube, which is attached quite a distance away from the microphone to a stand, and he's measuring the speaker response of woofer and tweeter in a coaxial outdoors, with the speaker mounted on a stand. He claims that this is comparable to an anechoic chamber.
I'm hamstrung by only speaking English, but I'd guess it's a gated impulse response. He has the microphone on the end of a long tube to avoid the very early reflections that would a present with a "traditional" mic stand/holder. Above around 1kHz or 2 kHz, it won't be any different to an anechoic chamber. Below that frequency range the results will become of progressively lower resolution to the point they're of no value.
