Speaker testing without anechoic chamber
Old 18th May 2012, 07:21 PM   #21
KSTR is offline KSTR  Germany
KSTR's Avatar
Originally Posted by AndrewT View Post
Lay the test source on it's back in the middle of the football pitch.
Mount the microphone of a mast and hang it about 10' above the upward facing source.
Doesn't work unless you dig a pit as well, the baffle must be flush with the earth surface, otherwise you will see a pretty perfect comb filter pattern, depending of the depth of the box.
Old 19th May 2012, 04:34 AM   #22
CharlieLaub is offline CharlieLaub  United States
I strongly suggest that you get a copy of a real measurement software, like ARTA. It's free as a demo version (but full featured). Then read the following tech note about measurements:
http://www.artalabs.hr/AppNotes/AP4_...d-Rev03eng.pdf
This goes in to more details about the science behind these measurements:
http://www.xlrtechs.com/dbkeele.com/...ld%20Paper.pdf
This is how to do it!
-Charlie
Old 12th February 2019, 02:16 PM   #23
shkumar4963 is offline shkumar4963  United States
Deleted
Speaker testing without anechoic chamberHide this!Advertise here!
Check my First Box & Measure in anechoic chamber endrek Subwoofers 54 20th September 2013 02:58 AM
Makeshift Anechoic Chamber Silent Screamer Equipment & Tools 17 4th April 2012 12:00 AM
offset driver with coupling chamber/throat chamber: possible with MJK mathcad models? gafhenderson Full Range 0 30th March 2012 11:35 PM
Dual Chamber Speaker Box suministros Multi-Way 17 19th May 2010 11:23 PM
DIY anechoic chamber! Snickers-is Multi-Way 33 13th March 2005 07:30 PM
Copyright ©1999-2019 diyAudio
