Using various speaker box designers, I'm coming up with very large Vb when using a qtc of 0.707. How bad would it be to have a higher qtc (0.8 or 0.85) for this woofer:
12" Square Frame Paper Cone Woofer White 290-914
How much will sound quality suffer?
With a Qts of 0.69 a box sim will suggest silly sized boxes for Qbox = 0.71.
You have to accept a higher Q alignment, and the driver is intended to
be used in boxes with a Qbox >1. Qbox =1 is 5.5cuft which is similar
to Vas and going bigger won't help that much, you need 10 cuft to
get to Q=0.9, and 20cuft to get to Q=0.8.
You should accept that the driver works best an 3 to 4 cuft box with a
box Q of 1.1 to 1.2, probablty intended to be about 2cuft. If you think
Q=1.4 is bad, try some of the other cheap PE 12" in a 2 cuft box ......
One comes out with a Qbox near 3 ....
The Dayton Audio DC300-8 12" works well in a 2 to 3 cuft
sealed box, and well in 3 to 4 cuft boxes tuned low at 25Hz.
rgds, sreten.
rgds, sreten.
Perhaps the designer had the Linkwitz Transform in mind.
I would not be afraid of Q slightly over 1. Room modes will probably do a lot more harm.
For many years I have listened with pleasure to AR16's , they worked very well in our family room 8x4x2.7 meter.
Bass was quite qood...
AR16 Qtc=1,15 @55Hz according to AR specification.
0.85 Qtc calculates a ~0.43 dB peaking around 70 Hz in well stuffed ~115.44 L, so plenty good enough.
GM
"Cult of the Infinitely Baffled"Hear The Bass, Not The Box The definitive online resource for Infinite Baffle subwoofer designEstablished 1999 - Home Read the FAQ there.
Like AndrewT says - An infinite baffle.
TOO LOUD MUSIC
Krokkenoster
IF I WANT TO TEST A HI FIDELITY SET I TURN THE VOLUME DOWN SO THAT I CAN HEAR THAT HORRIBLE DRY SOUND AND THEN SEND THEM TO THE TRASH CROSS-OVER DISTORTION IS BAD AND INAUDIBLE WHEN MY EARS RING FROM LOUD NOISE.......I MEAN "MUSIC" GUYS HONESTLY MY WORKMATES GOT DEAF AND IF YOU GOT TO WORK IN DISCO'S WEAR SAFETY EAR BUDS IT IS HORRIBLE TO HEAR THE SWISHING SOUND OF AN OLD F.M. RADIO THAT IS NOT TUNED TO A STATIONALL THE TIME THAT YOU ARE AWAKE0.85 Qtc calculates a ~0.43 dB peaking around 70 Hz in well stuffed ~115.44 L, so plenty good enough.
GM
Krokkenoster
Or no box at all?
Maybe this driver is intended for infinite baffle, i.e. a hole in the
wall between two rooms that are isolated from each other.
No. Most drivers of this type are intended for boxes with higher Q
than 1.0. They also generally don't have any BSC so it sounds far
less worse than you might think, used in many commercial speakers.
rgds, sreten.
GM
Hi, I calculate 280L to get down to Qbox = 0.9, somebody is wrong, rgds, sreten.
Coming from a guy with considerably less experience than some of the other gentlemen in your thread I'll stop short of saying box size isn't all that important ... it is ... but, you'd be hard pressed to actually tell the difference in driver response from Q =0.7 up to Q =1.0 I'd bet. Even Q =1.2 isn't like "holy crap, that's waaayyy too much bass for me" territory ... unless you can sense another 1db of gain down thereUsing various speaker box designers, I'm coming up with very large Vb when using a qtc of 0.707. How bad would it be to have a higher qtc (0.8 or 0.85) for this woofer:
As somebody has pointed out, your room would have a bigger influence on the bass response than the 0.707 to 0.8/8.5 Q would. I wouldn't even sweat this.
Consider an aperiodic enclosure with lots of stuffing.
AES E-Library Closed-Box Loudspeaker with a Series Capacitor
This might help.
This might help.
'Well stuffed' per Margolis, Small using fiberglass insulation,
so I assume you're using polyfil or similar.
GM
What % increase in box volume are you suggesting is possible
"well stuffed" ? Do you have a link to "per Margolis" ?
rgds, sreten.
Greets!
The formulas were for a HP computer program in a JAES paper done by Gary Margolis [JBL] and Richard Small sometime around 1980, but my copy is long gone, so best I can do ATM. I do remember it either not elaborating on the various values or me not understanding the math, so asked my contact at Altec about how to interpret it and according to him it basically boiled down to 1"^3 of acoustic fiberglass insulation = 1.5"^3 of air.
From experience I know that in doing ~aperiodic alignments that it equates to a Ql = ~1 in BoxPlot 3.07, if that helps.
Bottom line, we're talking about this type/amount of stuffing where a net is put over the driver, etc. to protect it and would have posted this if the OP wanted to go with this alignment. IIRC bjorno has posted some math about how this much stuffing alters the driver's T/S specs.
GM
GM
that is equivalent to saying the speaker hehaves as if the box had 50% more volume.................. it basically boiled down to 1"^3 of acoustic fiberglass insulation = 1.5"^3 of air...........
I have seen figures quoted around +20% for sealed boxes. I wonder if that applies to an open box?
...IIRC bjorno has posted some math about how this much stuffing alters the driver's T/S specs...
Hi GM,
I guess you are referring:
http://www.diyaudio.com/forums/multi-way/83982-enclosure-high-q-driver-3.html#post976183
http://www.diyaudio.com/forums/subw...e-braking-one-coil-shorted-3.html#post1120919
b
The '50s, '60s era DIY books I have lists 1.4x using fiberglas
Having no documentation from Altec or any of my builds to prove otherwise, I let it go. Then someone posted Tom Nousaine's tests that showed some interesting results that somewhat proved my claim, but more importantly for me it used pillow stuffing, which others confirmed had superceded the traditional insulation material I did/still do use and in a few experiments proved to my satisfaction that it isn't nearly as efficient for heavy damping, though I still haven't seen any rigorous test results for fiberglass: http://www.nousaine.com/pdfs/Box Stuffing.pdf
GM
- How bad is it to have a high qtc for a 12" woofer?
