How to calculate floor bounce reflection(cancellation)
Old 23rd September 2011, 04:28 PM   #1
jtsaudio is offline jtsaudio  United States
Default How to calculate floor bounce reflection(cancellation)
I have a 6" two way tower speaker that I may add a larger woofer to for more extended bass.
I read somewhere that there is a floor-bounce cancellation related to woofer height (Allison effect?).
The 6" driver is approximately 30 inches from the floor.
How do I determine the frequency at which this occurs, and how will/should this affect my choice of lower-end crossover frequencies?
Thank you.
Joe
Old 23rd September 2011, 04:48 PM   #2
dantheman is offline dantheman  United States
dantheman's Avatar
This will help:
Floor/Ceiling Reflection Calculator
audio blog: A little more into boundary conditions
Dan
My Blog
My Music Recordings
Old 23rd September 2011, 05:10 PM   #3
CharlieLaub is offline CharlieLaub  United States
This Excel spreadsheet based modeler written by Jeff Bagby does the same, and more:
Loudspeaker Design Software
-Charlie
Old 23rd September 2011, 05:17 PM   #4
DBMandrake is offline DBMandrake  Scotland
DBMandrake's Avatar
For a really quick, back of the napkin calculation, there is also this useful page:
- Simon
Old 23rd September 2011, 05:36 PM   #5
Michael Chua is offline Michael Chua  United States
The floor bounce is real. I picked this up while I was designing a 2-way with Zaph's ZA14W08. Speaker was on a 30" stand.
The cancellation doesn't show up in near field measurements. However, when the mic was placed 1 meter away, an in-room 20-20K ungated sweep registered a deep notch at approx 150Hz.
That's one reason why mid-bass is missing sometimes.
More measurements can be found at SWIFT
ampslab
Old 23rd September 2011, 06:09 PM   #6
A 3-way with the woofer located at or very near the floor, and the woofer-midrange crossover point at or above 200Hz, can completely eliminate this problem.
-Charlie
Old 23rd September 2011, 06:10 PM   #7
Wayne Parham is offline Wayne Parham  United States
Wayne Parham's Avatar
Floor bounce definitely is real. So is the notch from the wall behind the speakers. Vertical axis room modes also tend to fall in this frequency range. Really messes up the lower midrange.
I tend to suggest flanking subs to mitigate this problem. Run a "helper woofer" just a smidge on the high side, like just north of 100Hz. It will smooth the lower midrange, sort of filling in the holes from the self-interference notches.
Visit the π Speakers website
High-quality audiophile loudspeakers and kits
Old 23rd September 2011, 06:14 PM   #8
-Charlie
Definitely. I either run a three-way with mid and woofer blended between 100Hz and 250Hz or, if I run a stand-mounted two-way, I run flanking subs, which effectively do the same thing. I don't usually run flanking subs quite that high, but I do let them blend in the octave above 100Hz.
Old 23rd September 2011, 06:28 PM   #9
bbggg is offline bbggg  United States
It's dead simple both to visualize and to calculate. You have to imagine a mirror image of the driver deep inside the floor. When sound emission from the driver itself and from this subterranean image are in antiphase, there is cancellation. This happens when path length difference is half a wavelength. You calculate the path length difference by calculating two hypotenuses and subtracting one from the other, and then divide the speed of sound by the result: this number is twice the frequency in question.
Old 14th April 2013, 03:41 PM   #10
fatmarley is offline fatmarley  England
Could I use a 10" wide baffle and still cross over around 200Hz with a floor mounted woofer? Or do you have to use a wider baffle for this to work?
How to calculate floor bounce reflection(cancellation)Hide this!Advertise here!
need to bounce some tonearm ideas around... Jim Leach Analogue Source 10 10th March 2010 12:27 PM
Contact bounce rho Solid State 6 10th March 2005 08:31 PM
pga2310 and switch bounce biff584 Digital Source 4 3rd April 2004 01:42 AM
Ground Bounce/ Oscillations in SPDIF fmak Digital Source 24 6th March 2004 07:52 PM
HOw close does driver need to be to floor to avoid floor bounce? Kanga Multi-Way 8 24th April 2003 06:09 AM
Copyright ©1999-2019 diyAudio
