Introduction to designing crossovers without measurement
Old 26th March 2019, 10:21 AM   #671
AllenB is offline AllenB  Australia
You didn't go wrong. Third order filters are not obvious. Resonance equations may not help.
But this is a waveguide design with a 12" woofer and I guess the crossover frequency is 1k5Hz.
Old 26th March 2019, 10:33 AM   #672
sumotan is offline sumotan  Indonesia
Hi Allen thank you again. Seldom see the use of 3rd order XO.
I guess the best way for me know is to build the XO & get some simple equipment & software to measure & learn frm there.
Old 26th March 2019, 10:39 AM   #673
If you design the crossover well, it makes only a small difference between second order, third and fourth, and then only when there is a reason. For example, the order must be big enough to cut the woofer breakup and let the tweeter play loud enough.
Old 26th March 2019, 11:25 AM   #674
Understand Allen thank you again & also to Pico for the tutorial.
Will learn as much as I can.
Take care & Cheers
Old 28th March 2019, 04:11 AM   #675
chithanhhaichau is offline chithanhhaichau
thank you so much for sharing
Old 3rd May 2019, 11:04 AM   #676
leo2 is offline leo2  Netherlands
Hi Allen. When I choose a woofer which is more than 6dB below my tweeters efficiency, how
do I calculate this. In your tutorial it goes up to a difference of 6dB.
For instance when the difference is 8dB do I multiply the tweeter's impedance value by
1.4 ? Or do I have to choose different drivers.
Old 3rd May 2019, 11:39 AM   #677
There is no problem with 8dB. Ideally you could use an L-pad. This is one series resistor and one in parallel. Since these work in a reasonably predictable way, it should be OK to use an online L-pad calculator.
Old 3rd May 2019, 01:39 PM   #678
Thanks Allen.
One question about an L-pad. Do I skip the the 10 or 20 ohm resistor from your tutorial and
just use the L-pad.?
The tweeter I want to use is a 6 ohm tweeter and with a 10 ohm resistor it will give me
3.75 ohm which I also use in calculating the second order crossover on the tweeter.
Now are these L-pad calculators designed to keep the tweeter at 6 ohm, or will it change the
tweeters impedance?
Old 3rd May 2019, 07:06 PM   #679
The idea with an L-pad would be to keep it at 6 ohms. Specifying this is part of the design procedure. It is also possible to take the impedance to another value but keeping it at 6 will be more likely to work as expected.
Old 4th May 2019, 05:59 AM   #680
Thanks again, Allen
Introduction to designing crossovers without measurementHide this!Advertise here!
WinSpeakerz vs others for measurement & crossovers rick57 Multi-Way 8 12th December 2010 10:20 PM
Designing crossovers using Vidsonix Virtual Crossover triode4 Multi-Way 0 28th October 2007 01:22 AM
A brief introduction WayneM Introductions 7 30th April 2005 01:23 AM
Designing passive tri-mode crossovers? Datoyminaytah Multi-Way 9 4th September 2004 12:33 PM
Designing for guys who like designing Sch3mat1c Tubes / Valves 14 31st August 2003 11:46 AM
Copyright ©1999-2019 diyAudio
