Introduction to designing crossovers without measurement
Thread Tools
Old 3rd December 2015, 03:36 PM   #421
ShaneF is offline ShaneF
I wish I could buy two more of these bass drivers but they're nowhere to be found.
Old 3rd December 2015, 04:40 PM   #422
R.I.P.
Next time you build, try to get the treble closer to the mid driver.
You can even trim a bit off the treble faceplate to get it closer still. 10mm cut off would be good.
The higher the crossover frequency, the more important the "closeness" becomes.
regards Andrew T.
Old 3rd December 2015, 05:11 PM   #423
That's an interesting thing you bring up. While the photograph I produced has cheap cell phone lens distortion, the distance between the 2 drivers is 1cm.
However.
I have considered replacing the 4 inch Audax with a Morel 5 inch. I would like the increased power handling and a touch more bottom end from the larger driver. I am considering the Morel CAW 538.
http://solen.ca/wp-content/uploads/CAW538.pdf
Old 6th December 2015, 12:20 AM   #424
djn is offline djn  United States
djn's Avatar
Wow. Great stuff AllenB. As you read in my thread I I building crossovers right now and printed out all your post and will follow them as a starting point. Thanks again.
Old 7th December 2015, 11:03 PM   #425
djn's Avatar
I took all the posts that AllenB wrote and turned them into a PDF document so I could print it out to work through my crossover design. Here is a copy if anyone is interested.
Old 8th December 2015, 03:25 AM   #426
AllenB is offline AllenB  Australia
AllenB's Avatar
That's excellent djn, there has been interest in a printable version. I should learn to make PDF documents this way.
Thank you.
Old 8th December 2015, 10:04 AM   #427
R.I.P.
Which pdf reader/writer did you use?
regards Andrew T.
Old 8th December 2015, 10:40 AM   #428
djn's Avatar
Thanks Allen. I laid it out in MS Word, then saved it as a PDF. No need to have Adobe.
Old 8th December 2015, 11:58 AM   #429
R.I.P.
I saw "Word" in file properties.
I had not thought about using Word's pdf export.
regards Andrew T.
Old 8th December 2015, 12:00 PM   #430
djn's Avatar
I use it with contracts all the time. That way nothing can be changed by someone else but I can make changes to the word file then save it as a PDF again.
Introduction to designing crossovers without measurementHide this!Advertise here!
Thread Tools
WinSpeakerz vs others for measurement & crossovers rick57 Multi-Way 8 12th December 2010 11:20 PM
Designing crossovers using Vidsonix Virtual Crossover triode4 Multi-Way 0 28th October 2007 02:22 AM
A brief introduction WayneM Introductions 7 30th April 2005 02:23 AM
Designing passive tri-mode crossovers? Datoyminaytah Multi-Way 9 4th September 2004 01:33 PM
Designing for guys who like designing Sch3mat1c Tubes / Valves 14 31st August 2003 12:46 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
