How To Increase Driver Nominal Impedance?
Old 26th April 2011, 09:01 AM   #1
Jay is offline Jay  Indonesia
Banned
Default How To Increase Driver Nominal Impedance?
I have some 4 Ohm woofers that I want to use for 3-way. But because of the low impedance they are not so useful so I want to increase this nominal impedance by modifying it. Any suggestion on how I better do that? Here is what I want to do:
1) Change the wire of the voice coil using smaller diameter/gauge cable. Could be the same number of layer, or more if can be done without increasing the coil gap size.
2) Add more layers to the winding. The gap size will be made bigger to accommodate this change.
3) I don't want to increase the length of the coil winding (to avoid distortion)
Old 26th April 2011, 09:43 AM   #2
R.I.P.
wire two identical 4ohm driver voice coils in series to give an effective 8ohm loading.
regards Andrew T.
Old 26th April 2011, 10:36 AM   #3
Banned
Can I add only the coil (not the driver) in series? How much power/sensitivity is lost compared to adding a 8-ohm resistor? I think it wont work But never tried it before. I have to try it (even only once) just for the sake of experiencing it
Old 26th April 2011, 01:49 PM   #4
activexp is offline activexp  United Kingdom
activexp's Avatar
Send a message via ICQ to activexp Send a message via AIM to activexp Send a message via MSN to activexp Send a message via Yahoo to activexp
Originally Posted by Jay View Post
I have some 4 Ohm woofers that I want to use for 3-way. But because of the low impedance they are not so useful.... )
Why does the low impedance make them not so useful? Isn't modifying the driver a bit extreme? A bit risky I would have thought. If the mid and tweeter are 8 ohm and the XO designed correctly I can't see any problem with 4 ohm woofers. Unless I'm missing something
Old 26th April 2011, 02:09 PM   #5
gedlee is offline gedlee  United States
gedlee's Avatar
Any resistance that is added in series with the coil that is not linked to the flux for better driving force, lowers the efficiency.
And I would caution you about changing the coil unless you have a lot of experince at this - it is not an easy thing to do.
But, if you are insistant in changing the coil, then generally a smaller guage wire with more turns will result in basically the same efficiency at a higher impedance. You really can't change the gap on an assembled speaker - thats not possible, or at least not reasonably.
Earl Geddes Gedlee Website
Old 26th April 2011, 02:51 PM   #6
Banned
Actually I have some experience with this, but changing from small gauge wire to bigger gauge wire to "improve" the bass. Now I want to do the opposite to increase the impedance.
Yes, it is not difficult to change the gap size, because the outer ring is usually only around 3 mm thick. I have done this before.
BTW, thank you for confirming or giving the green light for proceeding with the plan. Actually I'm hoping there is other way that I cannot think of to lower the impedance.
Yes, I insist on doing this because in my prediction, with the anticipated crossover, the speaker impedance with 4-ohm woofer will easily reach 3-ohm (even lower) at some frequency.
Old 26th April 2011, 03:02 PM   #7
Banned
Hmmm... may be I'm just paranoid. I don't want the speaker system impedance to be too low. What do you think is the acceptable minimum impedance of current loudspeaker?
Old 26th April 2011, 03:10 PM   #8
18Hurts is offline 18Hurts  United States
So wiring the two 4 ohm woofers in series is out?
You would get your 8 ohms and another 3dB of output. The size of the box will go up which might be your issue.
The other option is to take the second woofer and make a bandpass box and stuff it somewhere. Say your woofer crosses at 800Hz, the bandpass box can be tuned for 40 to 80Hz and naturally filter out the other frequencies through the port. Stick it above the ceiling tiles, under furniture or make it a speaker stand.
It would be rather odd but it would work. If you need a speaker stand, it could be made to do that function and also boost the deep bass response while increasing the impedance to 8 ohms.
Old 26th April 2011, 03:31 PM   #9
activexp's Avatar
Difficult to say, really depends on the amp. If it's well designed it should be able to handle 4 ohms or less without distress.
Old 26th April 2011, 03:48 PM   #10
Banned
I don't understand. How can I bandpass a woofer to 40-80Hz while putting it in series with other woofer bandpassed for 80-800Hz??
How To Increase Driver Nominal Impedance?Hide this!Advertise here!
Determining a nominal impedance of a finished speaker rabbitz Multi-Way 4 26th October 2008 02:00 PM
nominal impedance conditions Ted205 Multi-Way 4 10th September 2008 11:26 AM
nominal impedance missmatch of drivers SamClassA Multi-Way 10 28th September 2006 09:17 AM
Need some rec's for nominal power, nominal cost amps goskers Solid State 1 6th April 2003 01:24 AM
Copyright ©1999-2019 diyAudio
