i am envisioning a more compact version of a multi horn speaker system.
placing the highs horn on the outer rim of the bass horn and the mids some where just inside of the bass horn at an angle where they punch through so they are facing forward.
just an idea open for ideas and critique.
opps misspelled "for" in the title. mod can you fix for me?
You can see the always impressive RCF H1312 (pdf) powerhouse.
System sensitivity1: 98dB LF, 106 dB MF/HF
Rated maximum SPL: LF 134 dB - MF/HF 137 dB
With F3=67Hz it needs a sub.
I know that what you want is more like complex mid-horns
Design consideration of a MID-horn
and here
Unity horn
and here
Unity horn
