Honestly don't know, just imagine the minor fundamentals, harmonic structures will blend with whatever dominates and the cavity will create a notch somewhere in the room response.
Angled walls turns the room into a horn of sorts and if > 12 deg included will allow 'slap'/flutter echo to decay quickly enough to not be an issue, so a good thing and one reason why cinemas, symphony halls expand to the rear.
Obviously, > 4 walls is going to increasingly randomize its eigenmodes, 'slap'/flutter echo, etc., so can be the makings of an above average audio/video room. You want a neat room for audio/video; expand walls, ceiling from the sound wall >12 deg. and make the rear wall a deep 'V' [> 12 deg angles] facing into the room to breakup/randomize the bass. AKA live end/dead end [LEDE]. One adaptation of the principle with 'V' to the rear: 20,000 Watt Home Hi-Fi System
GM
GM
This eBay seller is making his own multi-cell horns by the looks of it:
MK1005A Multicell Horn for 1,4" driver Altec288 | eBay
What is the obsolete part about them? Aside from difficult manufacturing.
The modern tweeter horn would play from 3Khz up.
So we are looking at the multi cell to cover approximately 600 Hz to 3 kHz. The question then becomes what are the issues with the multi cell in that specific range?
Multicellular horns may be obsolete, but that doesn't mean they are no longer used. On the contrary I would say.
Traditional exponential multicellular horns are reportedly subject to beaming and multicell comb filtering, aka fingering.
Pat Brown published EASE and CLF ballon data of an Altec 1005 on SynAudCon.
Unfortunately, the files are no longer retrievable, not even through archive.org.
Who wouldn't want this?:
- Multicell horns
