3rd Order Harmonic Distortion in my in-room measurements
Thread Tools
Old 23rd November 2009, 12:35 PM   #1
wigginjs is offline wigginjs  United States
wigginjs's Avatar
Default 3rd Order Harmonic Distortion in my in-room measurements
I've been doing some in-room measurements of my speakers at my listening position and I'm seeing large amounts (~10%) 3rd order harmonic distortion throughout the entire measurement, but very low (~0.1%) 2rd order harmonic distortion. Is there something in particular about a measurement setup that would result in this? Or is this possibly due to room interaction? Why is 2nd so low, but 3rd so high?
Old 23rd November 2009, 01:27 PM   #2
breez is offline breez  Finland
What frequency range are you measuring? Low frequency measurements may not be very useful because of modes amplifying and attenuating both the fundamental and distortion components.
What kind of measurement is it? Perhaps logsweep or just a single tone with spectrum analyzer?
Old 23rd November 2009, 01:31 PM   #3
Pano is offline Pano  United States
Pano's Avatar
Yes, please tell us more about your measurements.
And do you get similar results if you measure the speakers up close?
Take the Speaker Voltage Test!
Old 23rd November 2009, 01:44 PM   #4
wigginjs's Avatar
I'm measuring 10Hz - 20KHz with ARTA "Steps", so I guess that's a series of single tone measurements. I have not compared it to up-close measurements. That would probably be a really good diagnostic step.
Old 23rd November 2009, 01:46 PM   #5
doug20 is offline doug20  United States
Are your measurements Gated? I would say if you are measuring below 200Hz then they probably aren't ?
btw, I use ARTA too so I do have a side question. Did you get ARTA calibrated so its displays the right SPL values? I can never get the SPL calibrated to show the right values
Old 23rd November 2009, 01:50 PM   #6
Andi is offline Andi  Germany
use the logsweep with arta to confirm. normally you might not necesserly hear this 3rd order distortion, it is hard on the boarder of perception i would say. are the other harmonics also very high, when you go on distortion d%, you can see the others too. if there also high, than it might be distortion in your measurement set up, or maybe dirt in the voice coil....????
Old 23rd November 2009, 03:14 PM   #7
JohnPM is offline JohnPM  United Kingdom
Odd harmonics may be an indication of clipping somewhere in the measurement chain.
Old 23rd November 2009, 06:21 PM   #8
Pano's Avatar
Yes indeed! That's why a closed mic'd measurement would help.
  Reply to this post
3rd Order Harmonic Distortion in my in-room measurementsHide this!Advertise here!
Thread Tools
Why is distortion harmonic? dsavitsk Tubes / Valves 48 12th March 2008 02:49 AM
Single Ended, Single driver: In-room distortion measurements Gerrit Boers Full Range 4 27th November 2007 08:12 AM
What effect does a TL have on harmonic distortion? owdi Multi-Way 0 26th April 2006 03:55 PM
second harmonic distortion tenderland Tubes / Valves 5 5th August 2004 11:29 AM
Non Linear Distortion testing - Harmonic Distortion JMB Multi-Way 0 20th July 2004 02:54 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
