HELP: xmax and  open baffles
Old 5th October 2009, 06:41 AM   #71
gainphile is offline gainphile  Australia
gainphile's Avatar
Modelling recatangular baffles are not easy. If you like math, this is a good read. Basically they can be modelled by an equivalent circular baffle:
http://www.musicanddesign.com/Equivalent_Baffles.html
My path of least resistance is simply to build and measure, with some educated guess from past experience. Wood cost only $3 anyway. YMMV
Again, I can't recommend enough JohnK's modelling tool (ABCDipole). Great $14 investment I think.
Anyway sorry for being off-topic to the OP. I'll shut up now
http://gainphile.blogspot.com
Old 5th October 2009, 12:17 PM   #72
otto88 is offline otto88  Australia
otto88's Avatar
gainphile
Thank you for your suggestions
ABCDipole is probably a bargain, I must get to it soon.
However JK says rectangular baffles can be modelled by an equivalent circular baffle - at *low Hz, which is useful to know, but at present I was focussing on the upper mids to tweeter transition . .
The article doesn't clarify the measurement or estimate of D . .
Cheers
Old 6th October 2009, 09:35 AM   #73
otto88's Avatar
I realize I largely "hadn’t seen the forest for the trees".
If I understand correctly, JohnK's article and the Edge can estimate the extra distance the sound travels - perpendicular to (at 90 degrees to) the listener–speaker axis. And that’s probably the larger part of the extra distance travelled.
My sketch was focusing on the extra *depth ie front-to-back that the sound from the rear of the cone travels, to get to the same ‘plane’ as the sound from the front of the cone.
So we can use JohnK's article or the Edge for the main part (around the bafffle's width): can someone clarify how to quantify the extra *depth travelled?
Old 10th February 2019, 11:06 PM   #74
Pawelgreece is offline Pawelgreece  Poland
Interesting discussion.
My question out of curiosity,
How come Grandinote Mach 9 model with twenty something tweeters in line array avoid comb filtering?
Old 11th February 2019, 09:34 AM   #75
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
^ Grandinote - Mach 9
9 bass drivers with no xo, no eq and 16 tweeter in-line, height of 159cm
Avoiding comb filtering is nonsense, read more in other threads here
Line Array suggestions - 2 way
The making of: The Two Towers (a 25 driver Full Range line array)
Radikal aktivist AINOgradient speaker project
HELP: xmax and  open bafflesHide this!Advertise here!
New open baffles hurdy_gurdyman Multi-Way 3 26th September 2007 03:22 PM
FR125s in open baffles Fuling Full Range 33 7th August 2007 09:37 PM
$7 open baffles... planet10 Full Range 31 8th May 2005 08:45 AM
Open Baffles :- ) brianon Multi-Way 17 3rd February 2004 09:13 PM
Open baffles? dc Multi-Way 5 28th December 2001 03:10 AM
Copyright ©1999-2019 diyAudio
