Jean Michel  on LeCleac'h  horns
Old 5th September 2013, 05:36 PM   #1531
Rewind is offline Rewind  Sweden
Rewind's Avatar
Originally Posted by Richidoo View Post
What driver?
The driver is called Federal Sound FS100W.
Old 5th September 2013, 08:04 PM   #1532
Richidoo is offline Richidoo  United States
After looking over the FR curves on the azurahorn website, it seems I'd be better off using a 500hz horn with a 1" driver for the treble instead of a 200Hz horn.
Old 6th September 2013, 01:25 AM   #1533
Pano is online now Pano  United States
Pano's Avatar
Looking at FR curves is a good idea, but don't let that be your only guide. At 500Hz up a 1.4" driver (or perhaps a 2") will sound much better than a 1". You can ask Lynn Olson about that, too. I'm sure the difference could be measured, but it doesn't show up in simple FR plots.
If you want to cross north of 1 KHz, then yes, a 1" might be a better choice.
Take the Speaker Voltage Test!
Old 6th September 2013, 01:56 AM   #1534
Gary P is offline Gary P
Gary P's Avatar
Originally Posted by ra7 View Post
Thanks Gary! So, this is not information that is easily available. Now, if you can tell me how to determine the exit angle of a horn, that'd be great. I am doing some reading of my own.
If you are trying to measure the entrance angle of of a horn you can use a General Tool #17 protractor.
If the measurement arm is cut down to 1/2" or so you can measure the exit angle of CD's that don't have the bug screen right at the exit.
General Tools and Instruments
http://www.pimmlabs.com/
Old 6th September 2013, 02:26 AM   #1535
Gary P's Avatar
Here is another impulse response measurement on a JMLC horn. The driver is the cheap parts express D250P-8 mounted on a 600Hz JMLC horn that I turned on my wood lathe last month.
I think the small ripples are from the high frequency ringing of the driver as seen below.
Gary
Old 6th September 2013, 06:37 AM   #1536
ScottG is offline ScottG  United States
Gary
-with smoothing at only 1/24th, yup - driver (not horn, or rather this horn). The only exception to this that can cause "hash" is less than excellent coupling between driver and horn. But with you.. yeah, HIGHLY unlikely.
perspective is everything
Old 6th September 2013, 09:07 AM   #1537
more10 is offline more10  Sweden
Big horns sound very dynamic. I have heard Hoktunas 200 Hz horns, they sound fantastic with a jbl 2441. They sounded so good I got myself a pair.
An externally hosted image should be here but it is no longer accessible. Please upload images instead of linking to them to prevent this.
I am using JBL 2482. I have only listened to them briefly, I have no place to put them yet. The small horns are LeCleach 1kHz horns driven by a Radian one inch. The big horns go from 300 to 2500.
Because they are circular they beam. I had to eq them about 6 dB at the top.
Old 6th September 2013, 09:11 AM   #1538
Rewind's Avatar
Are those things on the floor for midbass or bass? Either way, it looks like you are missing at least one channel.
It also seems you would need larger tweeter horns to reach down to 2500Hz. But if you add one or two channels, you could have chosen a smaller midhorn and run it from 500 or 600Hz. This is what I am doing, but your way is probably good too.
Old 6th September 2013, 09:45 AM   #1539
Those things on the floor are midhorns. They are too small. I need more mouth area. The bass horn you can see to the left behind the other horns, the lamp is placed on it.
The 1Kz horns just look small compared to the 200 Hz horns.
Old 6th September 2013, 10:01 AM   #1540
Rewind's Avatar
I still have not solved midbass myself. I will try to use compression drivers as low as possible. If they start to cut in my ears I will always have the Fane S 8M.
Jean Michel  on LeCleac'h  hornsHide this!Advertise here!
Copyright ©1999-2019 diyAudio
