Hi-End and Hi-Efficency loudspeakers (horn + onken)
Thread Tools
Old 30th October 2010, 05:16 PM   #301
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
I try to work with arta but I have to study it.
In hobby box it is simple.
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 30th October 2010, 06:01 PM   #302
Helmuth's Avatar
It seems arta can not measure shorter the 70msec.
Maybe give holmresponse a try.
HOLM Acoustics
Old 30th October 2010, 06:03 PM   #303
doug20 is offline doug20  United States
What do you mean ARTA can not measure shorted then 70msec? It can do < 1 msec. I gate measurements with ARTA down to 3 msec all the time.
btw, you have a nice software package! Too bad its not in English.
Old 30th October 2010, 06:06 PM   #304
Helmuth's Avatar
Show how you can gate 1msec.
Old 30th October 2010, 06:25 PM   #305
a.wayne is offline a.wayne  United States
Sin Bin
Do you guys ever measure outside (gated or groundplane for eg) gating indoors below 800 hz is very difficult for accuracy , even if you have the speaker raised 1-2 M off the floor and a pretty large room...
Ok sorry , i see were you have Helmuth ......
Old 30th October 2010, 06:33 PM   #306
audiodesign is offline audiodesign  Italy
Banned
Send a message via MSN to audiodesign Hi-End and Hi-Efficency loudspeakers (horn + onken)
doug20, how to do ?
Old 30th October 2010, 11:17 PM   #307
Helmuth's Avatar
Originally Posted by audiodesign View Post
doug20, how to do ?
I found it.
Choose impulse response and you can choose custom gate.
Old 31st October 2010, 08:08 AM   #308
Banned
There is no big differences in the high frequency using 2, 5 or 20 msec.
Old 31st October 2010, 10:04 AM   #309
Helmuth's Avatar
That can be caused by the reflections on the baffle. I can see improvement with the 2 msec
Try now and measure with the microphone 10cm away from the tweeter and one 10cm away of the woofer and measure with about 3msec and 20msec.
and overlay them in a window.
When they are much more flat then you have to improve the shape of the baffle.
With this way of measurement (gating) you can tweak your design to the highest level.
Post a waterfall diagram looks very colour full in arta..
Old 31st October 2010, 10:36 AM   #310
Helmuth's Avatar
clic here.
Measure also a step-response waterfall.
The spec of the 15 inch woofer aso shows a bit ragged response in the d range like your measurements show. This can mean you have to tweak the cone of your woofer.
Make cuts and place damping lines like scanspeak does. To break cone resonance.
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
Hi-End and Hi-Efficency loudspeakers (horn + onken)Hide this!Advertise here!
Thread Tools
Commercial Front Loaded Horn Loudspeakers rabw Full Range 44 14th December 2005 11:11 PM
Efficency Confussion Mutley666 Multi-Way 10 25th May 2005 02:15 AM
TQWP, Onken, BL Horn AlexanderS Multi-Way 0 23rd March 2005 09:15 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
