2 way speaker ohm's question
Old 5th February 2009, 12:08 AM   #1
nukaidee is offline nukaidee  Canada
Default 2 way speaker ohm's question
I'm trying to build 2 drivers into a single box, does it matter if the woofer is a 8 ohm while the midrange is a 4ohm?
thanks
Old 5th February 2009, 12:40 AM   #2
Jonathan Bright is offline Jonathan Bright  Australia
Hi. The short answer is NO. No problems
There are other things to consider. The amp must be able to drive a 4ohm load. The cross-over tables you consult will need to give the appropriate value for the different impedences (i.e. 4 and 8).
Otherwise shouldn't be an issue.
"It was the Springtime of the year when aunt is calling to aunt like mastodons bellowing across primeval swamps." P.G. Wodehouse.
Old 5th February 2009, 12:48 AM   #3
Richard Ellis is offline Richard Ellis  Argentina
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
No not really...
Remember speakers are designated as "8 Ohm"...but that really is an approximation as speakers are a dynamic thing. Speakers really have whats called an Impedence (Z).
The "rating" at eight ohms is kinda an average as the 'Impedence changes with frequency.
Provided your crossover is arranged OK the only other thing to consider is output level (SPL@1w,1M) at four Ohms , does it match the output of the woofer at eight ohms??
Recall the characteristics(Math) of a coil and a capacitor at differing frequencies....your coil will start to climb in ohms as frequencies go up, conversely you capacitor will climb in ohms as the frequency goes down....somewhere at your crossover frequency these two slopes will intersect.
1
Xc= --------------
6.28x frequency x Capacitance(microfarads)
Xl = 6.28 x frequency x Henries ( millihenries)
Take some graph paper & graph out some Impedences for your project.
_______________________________________Rick.......
Old 5th February 2009, 01:00 AM   #4
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Hi nukaidee, looks like you have your hands full again. On top of what Jonathan and Richard have said, remember that the midrange, if it has an open back, shouldn't go in the same box as a woofer. Why don't you post some driver info and what you are trying to do and maybe we can help. Is there a tweeter involved?
Old 5th February 2009, 01:24 AM   #5
yeah I was worried about the open back hence all my posts all over the place. I was looking at the tang bang drivers..
5" sub http://www.parts-express.com/pdf/264-826s.pdf
and
3" bamboo mid/high http://www.parts-express.com/pdf/264-844.pdf
initially i wasn't even going to put in a cross over... but maybe i'll throw in a cheap one that cuts at 800hz.
My crude calculations are showing approximately a 4L box would be suitable for both the drivers, but I guess I'm also wondering do I need to build a "barrier" semi dividing the 2 drivers and I would really like to keep it small, so I don't want to double it up to 8L. Ported would work too I guess, but from what I see, ported boxes are bigger than sealed enclosures.
btw. I'll be driving these things with a single ended tube amp.
2 way speaker ohm's questionHide this!Advertise here!
Old Speaker question Cxrazy Everything Else 1 27th December 2007 01:08 PM
Speaker + Amp Question? RXPike Car Audio 7 13th September 2007 12:41 AM
Question about a speaker HELP Little.AMP Multi-Way 1 15th November 2005 07:15 PM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 07:03 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
